Old 02-15-2009, 08:38 AM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Anyone running Royal Purple?
I've always had it in my Mustang and am considering using it in the Yaris too...right now the car only has 1000 miles on it with the factory oil. Any suggestions on when to change to synthetic?
firebird1999us is offline   Reply With Quote
Old 02-15-2009, 09:30 AM   #2
saspy
Drives: Toyota Yaris
did my switch on my first service 5000 km's with rp
saspy is offline   Reply With Quote
Old 02-15-2009, 10:33 AM   #3
firebird1999us
Drives: 2003 Mach 1
Did you do it yourself or have the dealer/oil change place do it?
I'm considering doing it myself because oil change places tend to be a real hassle
Old 02-15-2009, 11:55 AM   #4
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
Most oil change places only care about getting the job done as quick as possible, so they don't leave your car draining oil for too long.
I'd suggest doing it yourself, and leaving the care about an hour to drain the old oil, so you get as much of it out before putting in the new one.
DFA is offline   Reply With Quote
Old 02-15-2009, 12:05 PM   #5
firebird1999us
Drives: 2003 Mach 1
I've only ever changed the oil in my riding lawn tractor before...but I wouldn't imagine it's much different? Drain the oil, remove and replace the filter, add oil until it's full to the mark on the dipstick...did I miss anything?
Old 02-15-2009, 12:09 PM   #6
DFA
Compulsive Washer
DFA's Avatar
That's about it. Just be really careful not to overfill, and to store the oil somewhere to keep it from hurting the planet.
I'm almost sure there's an oil chance DIY guide somewhere in here, not sure if it was before the hack tho..
Old 02-15-2009, 01:16 PM   #7
Split
Drives: 2008 Yaris Sedan
Royal Purple is great, but AMSoil is better. Plus AMSoil comes in 0w20, whereas Royal Purple only comes in 5w20. That said though, my dad runs Royal Purple 0w40 in his 996TT-S and it seems to perform better than when he was running Mobil1 0w-40. (1% more power, 1mpg better FE, 2% less oil consumption -- all of which can be placebo effect, but who knows?)
Split is offline   Reply With Quote
Old 02-15-2009, 02:06 PM   #8
upyaris
Drives: 2008 Yaris Hatchback
The Yaris is the easiest of all cars to change oil. I have the 2" TRD lowering springs on mine and I don't even jack my car up to change the oil. I am running the Royal Purple in my car now and it seems to run a little smoother than the Mobil 1. I use the K&N oil filter as well.
2008 Meteorite Metallic Hatchback, TRD lowering springs, TRD rear sway bar, TRD exhaust, 17" LiquidMetal wheels w/ Yokohama "S" drive wheels, 10" Fusion subwoofer w/ 400 watt amp, infiniti speakers, AFE stage 2 CAI, 35% window tint, wind deflectors, euro taillights, NST SSK1 & SSK2, and NST lightweight pulleys!.
upyaris is offline   Reply With Quote
Old 02-15-2009, 02:27 PM   #9
firebird1999us
Drives: 2003 Mach 1
Just the K&N drop in or the CAI?
Old 02-15-2009, 02:29 PM   #10
upyaris
The K&N oil filter. I have the AFE CAI.
Old 02-15-2009, 07:35 PM   #11
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
HAd RP and dumped it after a week. Got MOTUL in there now but its the economy grade and not for rompin on the revs. RP gave the most power at the top of the rev band but somehow seemed sluggish down low around town. I assume you mean the RP std street oil, 5W-30, not the fancy race formula? Rp street, Its not full synth so changeover shouldnt be a prob.
TheSilkySmooth is offline   Reply With Quote
Old 02-15-2009, 07:37 PM   #12
TheSilkySmooth
Get one of thouse plastic cup-type filter wrench heads to help get the filter off. Works miracles. Only 3.5 Qts on th refill - 1/2 qt stays in the engine no matter how hard you try to drain it.
Old 02-15-2009, 07:51 PM   #13
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i use RP 5w30. love it! i also use the 75w90 trans fluid as well.
mikenacarato is offline   Reply With Quote
Old 02-16-2009, 07:48 AM   #14
The Shape
Drives: 2007 Yaris Sedan
I have always just poured in 4 qts. Is this really bad????
The Shape is offline   Reply With Quote
Old 02-16-2009, 08:04 AM   #15
1stToyota
1stToyota's Avatar
Did Toyota issue an updated TSB? Their last one didn't recommend 0w-20 for the Yaris.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-16-2009, 10:25 AM   #16
Inspector14
Drives: 09 Yaris hatch, Meteor Metal
I have done a lot of my own oil changes. this Yaris is the easiest car i have ever worked on. i changed to synthetic at 800 miles. the factory oil in the car was causing a rough start and a lot of noise in the morning (was getting down to -18*F) so i switched to Pennzoil Platinum.
i plan on changing to castrol edge. which has a good portion of its base oil as a PAO. i would like to run AMSoil or redline though.
Inspector14 is offline   Reply With Quote
Old 02-16-2009, 12:18 PM   #17
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
http://www.yarisworld.com/forums/sea...earchid=407085
Originally Posted by xnamerxx
you nailed it sir.
Old 02-16-2009, 12:30 PM   #18
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
That is my question! Does anyone online use the 0W20 in their Yaris? I would be interested to know if there was a jump in mileage for going to 0W20?
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Aside the name,y is Royal Purple purple? Yawesh General Yaris / Vitz Discussion 6 01-10-2009 06:50 AM
AMSOIL vs Royal Purple IllusionX DIY / Maintenance / Service 44 12-02-2008 12:35 PM
Royal Purple FTW Nibs DIY / Maintenance / Service 11 09-28-2007 01:06 PM
Anyone familar with Royal Purple synthetic oil? Yaris_Fan DIY / Maintenance / Service 34 06-23-2007 12:29 AM
