Old 07-03-2016, 12:35 AM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
The auto trans > manual trans conversion guide
Here we go again with another big project, haha. If your Yaris has a automatic transmission and you want to know what's needed to get a manual trans in there, take a look.
1)Transmission and 75W90 fluid
2)*Axles can be reused*
3)Shift cables
4)Floor shifter assy
5)Clutch/brake pedal assy
6)Brake master cylinder for manual trans car
7)Clutch master cylinder and line to brake reservoir
8)Clutch slave cylinder, bolts and lines
9)Clutch kit and bolts
10)flywheel and bolts
11)ECM/Wiring
12)MT mounts
ArmstrongRacing is offline   Reply With Quote
Old 07-03-2016, 12:43 AM   #2
ArmstrongRacing
Data doesn't lie
I like to remove the engine and trans for this project, it gives you more room to work in the engine bay.
First step, remove the engine and auto trans, then split the two by removing the 6 12mm bolts behind the access cover, then remove the 14mm bell housing bolts and set your engine on a stand while you prep the chassis.
Old 07-03-2016, 12:46 AM   #3
ArmstrongRacing
Data doesn't lie
The pedals:
The AT brake pedal is one piece with one connector. You want to remove the pedal assy by disconnecting the brake light switch, then the return spring, then the pin to the booster. You then need to remove the upper dash pad via the service manual, then remove the top 12mm bolt. Now you can remove the (4) 12mm nuts on the main pedal bracket and pull the pedal out.
The MT pedal assy is 2 pieces, a clutch pedal and a brake pedal. (Before installation of the pedals you should install the clutch master). Start the install by sliding the clutch pedal assy over the clutch master studs and loosely attach the nuts, then install the top 12mm bolt and torque it all down. Attach the clutch master pin into the pedal and the return spring and plug in the clutch switch. Next, follow the same steps to install the brake pedal assy.
Old 07-03-2016, 12:46 AM   #4
ArmstrongRacing
Data doesn't lie
Clutch master install:
The automatic cars have no holes where the clutch master mounts, so you need to line up the clutch pedal withe the top bolt hole, trace the holes in the bracket, then drill out the holes. You can now slide the clutch master in and attach the hydraulic lines.
Old 07-03-2016, 12:47 AM   #5
ArmstrongRacing
Data doesn't lie
The brake master cylinder:
The MT part is different in only one way, it has a port on the bottom for the clutch hydraulics. You need to install the clutch master first because it's hard to get to. Start this by using a little 10mm line wrench to break loose the two brake lines on the master, then remove the (2) 12mm nuts holding the master to the brake booster. Unthread the brake lines the rest of the way then pull the master straight out of the booster.
You install the MT brake master then attach the hose from the clutch master on the side. Don't forget to fill with brake fluid and bleed the brakes/clutch once everything else is complete.
Old 07-03-2016, 12:48 AM   #6
ArmstrongRacing
Data doesn't lie
The shifter and cables:
You can see here the difference in the two cables, MT on the left and AT on the right. This is pretty easy, disconnect the cable ends and then get under the car. Remove the exhaust heat shield and then remove the (3) 10mm nuts securing the cable pass-through seal. Now you can just pull the AT cable out from the bottom, then feed in the 2 MT cables and secure the seal. The AT floor shifter is just (4) 12mm bolts and two electrical connectors, then install the MT shifter and connect the cables.
Old 07-03-2016, 12:49 AM   #7
ArmstrongRacing
Data doesn't lie
Flywheel and clutch:
The clutch and flywheel you need depends on your engine. If you keep your 1nz then a Yaris clutch is fine. But if you have a 2zr like me, you need these parts from a Scion Xd. You will also need flywheel bolts since they are different from the AT. Here is a picture of a Scion Xd disc on my Yaris C50 transmission...
Old 07-03-2016, 12:50 AM   #8
ArmstrongRacing
Data doesn't lie
The Yaris C50 transmission:
This is the easiest MT to swap in, you just need the mounts and this will go right in.
Old 07-03-2016, 12:51 AM   #9
ArmstrongRacing
Data doesn't lie
The trans install.
You will need the lift the engine off of its stand and get someone to hold the engine steady while you line up the transmission. First you put a small amount of grease on the input shaft and dowel pins, then you line up the input shaft with the clutch disc hole and wiggle/rotate the trans to align the two. When the shaft and disc align the trans will slide in and then you just align the dowel pins and install all of the bolts, but don't tighten until you get the starter in too.
Old 07-03-2016, 12:51 AM   #10
ArmstrongRacing
Data doesn't lie
Reserved for clutch slave
Old 10-23-2022, 03:33 PM   #11
Abel teshome
Drives: Toyota yaris
Can u tell as abt the throtel wiring ? Tnx
Abel teshome is offline   Reply With Quote
Old 07-03-2016, 12:54 AM   #12
ArmstrongRacing
Data doesn't lie
Reserved for wiring
Old 07-10-2016, 03:01 AM   #13
rabbito
rabbito's Avatar
just shift through gears...only 4 speed with tiny little engine...😂😂😂😂😂
Cosmetic: Toyota red emblem
Old 07-11-2016, 01:10 AM   #14
07dirtyaris
07dirtyaris's Avatar
Drives: meteorite metal 07 Hatch
I'm glad you are doing a write-up on this. I've been sourcing parts for a while to do this same project.
As soon as I get my subie to be a stable DD I'm going to do this same swap.
Look forward to watching your progress
07dirtyaris is offline   Reply With Quote
Old 07-12-2016, 12:38 AM   #15
ArmstrongRacing
Data doesn't lie
Optional Scion Xb 4.31 final drive swap
For those of you like me that want to maximize you acceleration, there is a complete drop-in 4.31 final drive available from the 04-06 Scion Xb. I scored this from a wrecked car and it had case damage, but the gears are still in good condition. This upgrade will change your in-gear top speeds to the following:
1st- 29mph
2nd- 54
3rd- 80
4th- 101
5th- 121
Old 07-12-2016, 10:49 PM   #16
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
So sex. The mechanical engineer in me gets a chubby looking at this stuff. The electrical engineer, on the other hand, doesn't give a flying rat's ass. ;)
Old 07-13-2016, 01:16 PM   #17
ArmstrongRacing
Data doesn't lie
And a bit of engine enamel to spice things up
Old 07-22-2016, 10:08 PM   #18
ArmstrongRacing
Data doesn't lie
Update:
The ARtrackbox case is done and prepared for assembly. We're just waiting on the Cusco LSD
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-24-2009 11:08 PM
Manual To Auto bronsin General Yaris / Vitz Discussion 10 12-22-2008 10:32 PM
What RPM's are you americans getting on Auto trans? BMGYaris General Yaris / Vitz Discussion 12 11-02-2006 02:43 AM
Manual vs. Auto littlecarlove General Yaris / Vitz Discussion 25 10-25-2006 08:45 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
