02-24-2009, 02:06 PM | #1 |
Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Effects of too much trans fluid in the case? (auto trans)
The thought kind of popped into my head and I was starting to think about it, so thought that I would make a post to see what others opinions are.
So yeah, what are some of the ill effcts of having too much trans fluid in the trans for an auto? What are some identifiable symptoms of there being too much? Etc.. |
02-24-2009, 02:52 PM | #2 |
Some fluid may be forced out of the seals.
02-24-2009, 05:48 PM | #3 |
Creates a mess and creates foam on the dipstick........ But it's not as bad as having to much engine oil.....
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy
02-24-2009, 09:38 PM | #4 | |
Drives: 2008 Yaris Join Date: Oct 2008
Foam reduces the volume of fluid through the transmission. Foam also reduces the heating capacity of the fluid and distorts the operation of the hydraulic system that governs the shift points and reduces pressure on the clutch packs. Lack of pressure on clutch packs and reduction in heat carrying capacity of foam causes local overheating and accelerated wear. This causes breakdown of fluid, increased wear and deposition of clutch pack material onto the pan at the bottom of the transmission. Clutch pack material is a sign of tranny wear. In older trannies its normal, in younger ones it's a sign of concern. Ultimately you vastly accelerate transmission wear, reduce its reliability and cause it to fail. You pay for a new Tranny. Gene |
02-24-2009, 10:59 PM | #5 |
Drives: 08 Yaris Sedan Join Date: Oct 2008
I think genew pretty much covered it.
02-24-2009, 11:08 PM | #6 |
So how long would it take then for the overfill to really do damage to the trans. And you were referring to an automatic yes?
Similar Threads | ||||
Reluctant upshift to 3rd while cold (auto trans) | pauljk | General Yaris / Vitz Discussion | 40 | 01-22-2011 06:04 AM |
manual trans fluid | d2dailly | DIY / Maintenance / Service | 65 | 02-14-2009 07:38 AM |
What RPM's are you americans getting on Auto trans? | BMGYaris | General Yaris / Vitz Discussion | 12 | 11-02-2006 02:43 AM |
Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
