Old 06-28-2007, 01:18 PM   #91
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wow that advance by 10 deg.. but retards at almost 20 degree....dang...
thanks bailout!!
Old 06-29-2007, 03:03 PM   #92
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Originally Posted by seriousfun View Post
Yes!
That didnt realy answer my main concern but thanks anyway.
Just wondering if it shows rmps consistantly....like an actual rpm gauge does...?? From stop to go, to stop again while driving~
I emailed the guy, but all he said was.....it tells you rpms of up to 9999.
Old 06-29-2007, 05:28 PM   #93
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
I have a scanguage II and I usually have it on the rpm setting. You can have 4 settings on the screen at the same time obviously choose what you want (cause there's more than four). Anway the rpm one is digital so there is A LITTLE delay, but its relatively quick as far as showing the change of rpm and yes from start to stop or cruising, and since its digital its going to jump around a lot, but it works, if that makes sense. To be honest when I first got it I was a little disapointed in the rpm display but I'm still happy with it. I generally know what rpm certain speeds are. I have an auto so its not like I really need it but its fun to know. And no its not analog like a tach usually is, its digital. Hope that helps!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 06-29-2007, 08:41 PM   #94
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
just a heads up for you future buyers...wish i saw this thread earlier
http://www.3n1autocomputer.com/groupbuy.html
saves ya some cash...
this is a fantastic tool.
Toyotech is offline   Reply With Quote
Old 06-29-2007, 09:29 PM   #95
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
WOOOOOOT, what group is this through? I appreciate it!
blacksan is offline   Reply With Quote
Old 06-29-2007, 09:39 PM   #96
Toyotech
??? corolla/matrix. u askin for a code or? sorry...just confused.
Old 06-30-2007, 05:21 AM   #97
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Thanks ECHOKnight2000, I really appreciate your response to that. I guess I wont mind a couple seconds of delay...just as long as I know about where in the clutch releasing it reaches a certain rpm before giving it gas.
Old 07-06-2007, 03:40 PM   #98
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have just sighted this ScanGauge Mounting kit on eBay. What do you guys think? Other than the price, it looks like it might be the perfect addition to the ScanGauge.
Old 07-06-2007, 04:20 PM   #99
BailOut
Steals terrorist's lunch
BailOut's Avatar
tk-421,
I'd pay $10 or $15 for something like that, but not $45.
Running the cable up to the windshield would be a PITA, too, but would look nice once it's done.
- Brian
Share the Road
Old 08-11-2007, 10:58 AM   #100
leasaunce
Drives: Toyota Yaris
question, can you change mpg to L/100km?? or mph to kph???
leasaunce is offline   Reply With Quote
Old 08-11-2007, 12:57 PM   #101
uncleyaris
NO!!
Old 08-11-2007, 09:12 PM   #102
EggMan
EggMan's Avatar
Drives: 2007 Yaris liftback
The answer is Yes. When KM is selected for distance and Liters are selected on fuel measurement, the fuel economy will be reported as mentioned. (LHK)
I found this info on page 14 as a note in the user manual.
My best run so far with this tool was 46.63 MPG. 40%city 60%highway. I have raised the tire pressure by 3 or 4 psi. I would like to know what other tricks can be applied for better fuel economy.
EggMan is offline   Reply With Quote
Old 08-12-2007, 02:35 AM   #103
Jerkratt
Jerkratt's Avatar
so how do you put in custom codes? stil cant figure that out ive had mine for a while now
"It hurts more when its wet"
Old 08-12-2007, 12:47 PM   #104
EggMan
EggMan's Avatar
From main menu, select options as fallows.
1. MORE
2. SETUP
3. UNITS
From here you can change from MPH to KMH and so forth.
Old 08-12-2007, 01:02 PM   #105
Jerkratt
Jerkratt's Avatar
that i know those are not custom codes those are the display
Old 08-12-2007, 04:08 PM   #106
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yes.
Old 08-14-2007, 08:59 AM   #107
yoyoche
yoyoche's Avatar
Drives: 07 sedan auto pacific blue
Found this neat post on Scanguage Tips & Tricks by Dan over at CleanMPG. You need to check it out.
http://www.cleanmpg.com/forums/scan-...icks-5901.html
Rostra Cruise control added
Scanguage II
Mudguards
Weathertech window visors
yoyoche is offline   Reply With Quote
Old 08-14-2007, 11:13 AM   #108
marcus
toyota
marcus's Avatar
cool!!!!!!!!!!1
