08-14-2007, 11:28 AM | #1 |
Drives: Yaris LB Turbo Join Date: Aug 2006
Under $2500 Turbo Kit w/Intercooler coming soon!
OK you guys have asked for it & you will get it. I have almost finished a turbo kit for under $2500. It will feature the following:
Custom manifold T25/T28 turbo with internal wastegate Front mount intercooler All piping, t bolt clamps, hardware, gaskets ect For engine managment I will be using one of the following: Camcom Blitz RVIT-i Apex SAFC AEM FIC I will sell the kit with or without the engine managment. I will be also trying each item & recomend the best one for the turbo kit. Now I read alot of people saying that when this alternative would come out they would jump on it like white on rice. Let's see who is on board. |
08-14-2007, 11:45 AM | #2 |
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
Cool, now I just need a supplemental income...even a winning lotto ticket would suffice
08-14-2007, 11:59 AM | #3 |
Drives: 07 Yaris Turbo Join Date: May 2007
First of all, thank you for your work on this, I'm glad some options are coming out for our cars.
I don't don't like internal wastegates in general, but... If you (1) show all kit parts clearly in pictures and an installed kit and (2) post dynos (preferably NOT on a Dynojet) then I'd be interested. 1. what wastegate are you using? (this is especially important with an internal wastegate) 1a. What spring will the wastegate come with? 2. what blowoff valve are you using? 3. Will the management come with a p 'n p harness? 4. is this going to use stock injectors? I can think of more questions, but lets' start with these.
08-14-2007, 12:21 PM | #4 | |
1) the tubo is made by Mitsubishi so it is made by them 1A) low boost 5lbs 3) No most will have to be hard wired (price is the issue) the Blitz plugs in to the port under the dash 4)depends on the results with them |
08-14-2007, 12:38 PM | #5 |
Drives: Yaris Join Date: Jun 2007
I had a feeling you where cooking up something after reading your recent posts and replys.
08-14-2007, 12:47 PM | #6 |
thanks for the answers. If you can reply to question 2. that would be good also.
As for wastegates, an internal one is fine as long as you never want to change anything, and it never fails. I like the flexibility, as I have never seen an aftermarket bolt-on turbo kit that didn't need quite a bit of tweaking for power and reliability. Hard wiring a management unit will add considerably to the cost. I am cool with that, but anyone considering this set up needs a really good tuning shop near them to wire it up and tune the car. I would interview the shop and get a quote before purchasing the kit. I hope the stock injectors work out, that would help keep the cost down -- the last set of four I bought cost about $350, does that sound about right for our car? Here's a question -- what are our stock injectors rated at in cc's?
08-14-2007, 01:53 PM | #7 | |
2) not sure yet, something inexpensive to keep the kit cost down As for the internal waste gate you do realize that some of them do come adjustable right? On the engine managment I am shooting for the Blitz unit to work since it is a plug n play unit. |
08-14-2007, 02:33 PM | #8 |
First Off... Thank you for doing this... I definitely Under-estimated you... and I'm sorry!
2nd: Who made the Custom Manifold? 3rd: Will there be a CAI available? 4th: Will you make a Stage 0 Kit, Without the Intercooler and all that piping? 5th: How much wood could a woodchuck Chuck, if a Woodchuck, could chuck wood?
*Philosophy of life... Brought to you by... "Nutzoids" Nutzoids... Where Punk rock is less about Image, and more about the Mind! |
08-14-2007, 02:49 PM | #9 |
+1
08-14-2007, 03:26 PM | #10 | |
CAI not nessesary for turbo kit Yes I will offer it without an I/C A wood chuck could chuck as much wood as a wood chuck could chuck if a wood chuck could chuck wood |
08-14-2007, 05:19 PM | #11 | |
Novice Hypermiler
08-14-2007, 08:08 PM | #12 |
how will you be able to deal with the adaptaion values being reset by the ecu?
08-14-2007, 09:01 PM | #13 | |
Drives: 2007 Yaris S Join Date: May 2006
and i would imagin at this point you would still need to keep the O2 sensor unpluged as the late ZPI had done...and until something big happens i would imagine we would have to keep the check engine light... |
08-15-2007, 02:32 AM | #14 |
Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
we can keep using a scan gauge or something and keep clearing the code..... lol
"It hurts more when its wet" |
08-15-2007, 11:56 AM | #15 |
08-15-2007, 12:06 PM | #16 |
der Zeck
we just need a CEL fix... anyone interested in getting ahold of the JDM turbo ECU? I do not know much about turbo's but would that solve some problems with the CEL?
08-15-2007, 03:31 PM | #17 |
About the CEL, I would like to know with the 2 guys that have the ZPI kit why they removed the O2 sensor? Also if they tried to use a O2 simulator.
08-15-2007, 04:50 PM | #18 |
Drives: 07 Join Date: May 2007
Is your car up and running? Sorry if I dont pay attention :P
Also, if it is, how long? Interested to see what you tune with and if the ECU learns around it..... |
Similar Threads | ||||
ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 02:24 AM |
ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 03:52 PM |
Garrett Turbo kit | elsteverino889 | Forced Induction Forum | 24 | 04-20-2007 11:27 AM |
ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 03:10 PM |
Turbo Kit Teaser Pics | cdydjded | Performance Modifications | 27 | 01-31-2007 01:58 AM |
