Old 11-25-2008, 04:46 PM   #37
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
do you guys seriously think every pound shed actually helps!!!!!....well you're damn right it does...
Old 11-25-2008, 10:21 PM   #38
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by YodaTheToyota View Post
Anyone tried removing tar sound deadening material from the Yaris. I did this on my Civic Si and it weighed a total of 28 pounds. Yaris probably has less of the stuff, if any. I haven't looked yet.
The stock air intake weighs 5 pounds. The Injen air intake I replaced mine with weighs 3 pounds.
if its the aluminum stuff you are probably looking at around .3lbs per sq ft, if its the non-aluminum stuff, probably even less. I can't imagine taking that stuff off, but to each their own.
Is the stock engine cover really needed? does it serve any purpose other than to look nice?
Old 11-25-2008, 10:48 PM   #39
jkuchta
Drives: 2007 Yaris hatch (red)
Nope...just looks nice...no fuction served that I can think of, other than shielding your arm from the hot cam cover when installing a header.
jkuchta is offline   Reply With Quote
Old 11-25-2008, 11:41 PM   #40
It might cut down the engine noise just a little --
Old 11-26-2008, 12:49 AM   #41
jkuchta
Good call.
Old 11-26-2008, 09:26 AM   #42
YodaTheToyota
Drives: 2008 White Yaris Base Liftback
Nope, I'm talking about the tar stuff that is under the carpet. It does add up. Look under the front carpet in the Yaris to see if Toyota used it. The other poster says they only put it in the seams. You use either a heat gun to soften it for scrapping it out with a plastic scraper or you use dry ice to freeze it and then it is brittle enough to chop out. My Civic had quite a bit of it, all throughout the car, especially in the trunk. Don't think Yaris has any in the back, but might in the front. I just haven't had time to check yet.
YodaTheToyota is offline   Reply With Quote
Old 11-26-2008, 11:16 AM   #43
jkuchta
I have no carpet, and I can say for sure that the "tar", which looks more like drywall putty or cake icing in the yaris, is only on the main panel seems.
Old 11-26-2008, 12:06 PM   #44
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
Talking
So are any of you lunatics that are ripping out your 60/40 seats interested in selling or trading them for the solid rear bench, by any chance?
WolfWings is offline   Reply With Quote
Old 11-26-2008, 12:57 PM   #45
JR (TEH_X_FALLEN) had his for sale, not sure if they are still available?
Old 11-26-2008, 01:01 PM   #46
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
I'm selling my 60 section, but I'm sure shipping would be quite high
Wanted: Forced Induction
Old 11-26-2008, 01:37 PM   #47
that weighs 55 pounds
Old 11-26-2008, 06:15 PM   #48
WolfWings
WolfWings's Avatar
I'd actually recommend shipping it in two pieces, it couldn't be more than $40 parcel-post via the USPS then, since it caps at about $20 for a 70-pound package, and two packages would be much less likely to end up 'too large' where you get pounded badly in oversize/overweight penalty-charges.
Old 11-26-2008, 07:14 PM   #49
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I only removed the lower part of the rear seats(the one you put your ass on) and it really didn't weight that much. The factory carpets are removed. The spare tire and trunk carpet and things also removed and the the jack and all tools removed.... I only feel more noise but just for my peace of mind I run the car with only $10 (some 4 gallons) of fuel just in case.
I wonder how much the front and rear windows weight? Those sure weight a few pounds.....
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 04:14 PM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
Yaris Curb Weight, difference LB vs Sedan CASTREX General Yaris / Vitz Discussion 14 12-12-2006 09:50 AM
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
