Old 01-05-2009, 06:35 PM   #19
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Well its very easy to change the filter. If you want to extend your drain interval you can just simple go under the car and remove the filter and install a new one. You will only loose like a quarter of quart of oil at most.
Old 01-05-2009, 07:20 PM   #20
Chupacabra
Drives: 2009 Yaris liftback
Originally Posted by TheSilkySmooth View Post
Did you measure cam lobe, and top of cyl bore? Or Just guessing. I just read on Jobbersworld Mobil-1 5W-30 does not even meet mineral oil Sm/GF-4 minimum spec for wear. Crazy huh?
I don't believe everything that I read.
Chupacabra is offline   Reply With Quote
Old 01-05-2009, 08:07 PM   #21
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
90915-YZZD3 is the filter used on toyota's larger engines... used to be called a "truck" filter because toyota didn't have any big "car" engines.. so it's sometimes referred to as a "truck" filter..
the big one...
but you should know this since you WORK for toyota....
i understood what you meant i just find it funny that your using a v8 filter with no problems......
Old 01-05-2009, 08:09 PM   #22
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by ROCKLAND TOYOTA View Post
please enlighten us some more on this "TRUCK" filter.....
yeah, sure looks like you knew what i was talking about
what "problems" would i run into running an oversized filter?
Originally Posted by xnamerxx
you nailed it sir.
Old 01-05-2009, 08:13 PM   #23
ROCKLAND TOYOTA
TRIM HUNTER
OH, i see for 2009 were still gonna be a asspaper, HUH. no problem, good luck with the thread...... unsubscribed
Old 01-05-2009, 09:02 PM   #24
Tamago
Tamago's Avatar
Drives: ZZW30
it's a serious question, what problems do you expect me to be having with a larger filter?
you nailed it sir.
Old 01-05-2009, 10:46 PM   #25
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
This is a legal statement from ASHLAND CHEM CO, they are vunerable for libel charges and loss of buisiness if false. I have found qualitatively a batch to batch variation on mineral oils I like, varying from: "kill the motor piss " to "wow, this is better than ANY SYN IVE USED". So I believe the is absolutre crap on the shelves waiting for you to snatch up. If you have ever worked in manufacturing environmen, you will know what I mean. Crap goes out the door ALL the time not meeting spec. And us, being ignorant consumers are not too savvy and dont have a 10 million dollar test lab to verify the quality, so too bad mama ...
TheSilkySmooth is offline   Reply With Quote
Old 01-06-2009, 10:45 AM   #26
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
You probably wont have any problems running a larger filter but if it costs more than the regular filter you are wasting your money.
Old 01-06-2009, 12:16 PM   #27
jambo101
jambo101's Avatar
toyota filters all cost about the same..
and having more filtering surface area, how would that be a waste of money? keep in mind i run 15W30 oil that gets a LOT hotter than was intended
If the oil filters all cost the same then use the one with more filtering capacity,odd that the engineers that designed the engine didnt recommend the larger capacity filter given that the price is about the same
Old 01-06-2009, 12:18 PM   #28
jambo101
jambo101's Avatar
Neat time dilation effect on the posting sequence
Old 01-06-2009, 12:31 PM   #29
Tamago
Tamago's Avatar
Drives: ZZW30
you nailed it sir.
Old 01-06-2009, 02:00 PM   #30
Tamago
Tamago's Avatar
Drives: ZZW30
haha i tried something it didn't work
you nailed it sir.
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-23-2008 11:45 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
don't think the dealer changed oil filter on first change gonzo452001 DIY / Maintenance / Service 0 01-13-2007 11:44 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
