Old 02-03-2009, 12:03 AM   #1
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Need help with lowering springs
I just purchased new rims and tires today, and I really want to take the chance and lower my sedan as well. I need some expert help please.
I got some 17" rims and the tires are 205/40/R17.
My question is, how low can I go, without having any problems?
Any help is greatly appreciated!!
GioBatera
Giobatera is offline   Reply With Quote
Old 02-03-2009, 12:49 AM   #2
Springs are common to both the liftback and the sedan, so keep in mind that any published drop will be greater on the sedan than the liftback (because it's heavier).
so Tanabe DF210 will be more than 2", NF 210 will be more than 1.4", etc. Maybe some sedan owner can help with more specific data for you.
Old 02-03-2009, 02:07 AM   #3
Hey Garm, I think the sedan is lighter by either 2 or 20 pounds. I really don't know why it gets lower tho.
OP, flip the rim around and look for the offset ("ET" and/or "+" x amount). If that number is at least 42, you're good to go as low as the Tein S.Tech's (what I have, although my offset on my 17's is only 40, I get slight rubbing on freeway dips). If it's lower than 42, you might want to stick to the more subtle drops, like TRD or Eibach.
Old 02-03-2009, 05:44 AM   #4
interested in some used megan coilovers? PM me
Old 02-03-2009, 08:27 AM   #5
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Thanks
I'm actually looking at some Elibachs. It's suppose to drop only about 1" F/R. I'm guessing it will be safer that way, and I'll still be able to feel the difference.
GioBatera
Old 02-03-2009, 05:49 PM   #6
Jaminjer
Drives: Sedan
I installed the nf210 on my 08 sedan, it dropped the rear 1.75 inches and 1.2 in the front. the rear drop was more than i wanted but does look good. If you buy lowering springs be sure to ask what the drop is for the sedan as most advertise the drop on the hb and the 2 are definately different.
Jaminjer is offline   Reply With Quote
Old 02-04-2009, 09:55 AM   #7
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Thanks! I end up getting the set of Elibach. It suppose to drop 1" F/ 1" R, so I'm taking in consideration the fact the for the sedan it should be a little more. Hopefully it will be all good!!!!
GioBatera
Old 02-04-2009, 11:14 AM   #8
i have eibachs in the my garage....i think ill be using them vs the coilovers come spring time
Old 02-04-2009, 01:38 PM   #9
supmet
Drives: 2007 4 Door Yaris
Holy crap he's right. I had to look it up on toyota to see it for myself.
MT 3dr yaris curb weight:2295
MT sedan yaris curb weight:2293
The auto transmission's weight isn't listed on the toyota site, but I'm guessing it outweighs both.
Old 02-04-2009, 01:49 PM   #10
ZING
ZING's Avatar
Drives: Yaris '09,GTi '09, BMW 3.30ci
You wanted the rear to sit higher than the front? Or is the rear lower than the front now?
ZING is offline   Reply With Quote
Old 02-04-2009, 04:38 PM   #11
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Well, I'll be dropping 1" front and rear. I strongly believe that it's gonna b about 1.3" or so, total
GioBatera
Old 02-04-2009, 07:36 PM   #12
supmet
Let us know how they feel and if you rub. I'm probably gonna end up going with the TRD springs on 16s. Are you keeping the rest of the suspension stock?
Old 02-05-2009, 08:27 AM   #13
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Yeah, at least for now...
GioBatera
Old 02-05-2009, 04:05 PM   #14
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
New question. Anyone know if I need to get a camber kit to lower a Yaris sedan? Please help..as I'm getting ready to do it.
Thanks!
GioBatera
Old 02-05-2009, 04:10 PM   #15
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
when you get ready to lower, PM me, i'll lower it for $80 labor.
i've done a couple yarii on this forum
Originally Posted by xnamerxx
you nailed it sir.
Old 02-05-2009, 04:28 PM   #16
drop on the sedan is greater in the rear than the hatch because of the difference in weight over the rear axle
Old 02-05-2009, 04:50 PM   #17
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Ok bro. I'll let you know. Do you do other stuff as well?
GioBatera
Old 02-05-2009, 06:49 PM   #18
Tamago
Tamago's Avatar
Drives: ZZW30
u name it, i'll do it..
you nailed it sir.
Tags
dropping, lowering car, springs
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Which lowering springs? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-25-2008 12:18 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
