Old 11-02-2008, 11:44 PM   #37
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
This oil gets trapped in the throttle body at cool down,this will help in the long run.Now go and post your BS some where else.
eco is offline   Reply With Quote
Old 11-02-2008, 11:54 PM   #38
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Send a message via AIM to YarisSedan
Originally Posted by john21031 View Post
Oh, not another one "i also inveted a wheel"... in the line with those $5 inline gas savers.
The oil vapor is circulating in the PCV "positive crankcase ventilation" system. Now you are just collecting it for some reason. Why not start condensing moisture out of all air inside and outside the car and then praise the device for the "unwanted" water it "trapped"...
Well after about 30k miles look down your throttle body. YOu will see enough black crap to possibly fill a mason jar that is coating the inside of your entire throttle body. Compare another yaris who has done this mod and guess what. It will be spotless.
Old 11-03-2008, 07:48 AM   #39
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Drives a '95 Nissan Altima?
Old 05-06-2009, 11:37 PM   #40
EasyDriver
Drives: 2008 Yaris Meteorite LB
$3.00 oil catch can...
I found this fuel filter "catch can" here:
http://www.tgilmore.com/talon/catchcan.html
How can you beat this price....and it's reusable!
EasyDriver is offline   Reply With Quote
Old 05-07-2009, 12:02 AM   #41
Pitt Yaris
Drives: Flint Mica Sedan
Very cool mod. Might try this soon.
Old 05-10-2009, 08:10 AM   #42
Fenrizwolf
I used to have more posts
Drives: '10HyundaiTucson'07Impreza
Neat!
Ditto!
Fenrizwolf is offline   Reply With Quote
Old 05-10-2009, 10:36 AM   #43
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
still dont get what this thing is suppose to catch..isnt that what the oil filter do?? just curious..
Old 05-10-2009, 11:02 AM   #44
OK, here's a basic explanation... Look at pictures of an engine, it's mostly hollow inside, and oil splashes around where it's not supposed to... So in order to keep things clean, there is some air that is sucked through the engine that picks up some of this oil, and circulates it back into the intake, so that it is burned by the normal engine combustion. This is a pretty efficient system, but it has the disadvantage of building up oil inside your air intake manifold, and also, burning oil is not very clean. So an oil catch can catches this oil before it gets back into the engine, so that you can dispose of it properly later on.
For more detailed information:
http://en.wikipedia.org/wiki/Positiv...se_Ventilation
Old 05-10-2009, 02:42 PM   #45
Fenrizwolf
more explanation, if you ever worked in a kitchen, there is an exhaust fan with "hood vents" above the grill and fryer's. They suck up the smoke and greasy air, and the vents catch the grease before it gets to the exhaust fan. So our engine is the grill and fryer's making smoke and greasy hot air, this diy filter is the "vents" that catch the oil or greasy hot air, and our intake is the exaust fan that we are keeping clean and not greasy dirty.
So i wonder if this means pretty much any fuel filter will work for this?
that black topped one looks just like the diy ones....
Old 05-10-2009, 07:59 PM   #46
marcus
toyota
marcus's Avatar
thanks guys that make alot more sense now....new project..!
by the was would a 1/4 inch fit..home depot only sells 1/4 inch size..
Old 05-10-2009, 09:41 PM   #47
Fenrizwolf
look at this toyota fuel filter i found
Old 05-10-2009, 11:52 PM   #48
EasyDriver
This is an impressive collection of fuel filters...I didn't realize that they made so many different types!!
Old 05-10-2009, 11:54 PM   #49
EasyDriver
This toyota fuel filter look like it has the glass bowl....as in the old days!!!! It would do the job excellently though.
Old 05-11-2009, 08:24 AM   #50
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
or you could buy:
an it won't look like you put an air compressor filter under your hood ;)
Originally Posted by xnamerxx
you nailed it sir.
Old 05-11-2009, 11:14 AM   #51
marcus
toyota
marcus's Avatar
if the filter tubing is smaller than stock would than restrict air coming out of the engine..
also what will happen if you forget to clean the filter and it gets filled would that block the air to comeout of the engine..and would that damage the engine for not getting that excess air out.??
Old 05-11-2009, 07:16 PM   #52
marcus
toyota
marcus's Avatar
does this work..lolz
Old 05-11-2009, 07:47 PM   #53
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
no, you CANNOT have a breather on there. it will cause a vacuum leak and the car will run rough. i had this issue when i tried to do it.
mikenacarato is offline   Reply With Quote
Old 05-12-2009, 11:23 AM   #54
marcus
toyota
marcus's Avatar
how much does the husky collect based on km or mile run ? what if u forget to clear it and it gets full??
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
