04-08-2009, 09:47 PM | #19 |
Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
I've got the C2 series. It's a good thing Autometer has so many lines of gauges, we've gotta be individualistic. Is yours digital like Mike's or full range electric?
Here's mine.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
04-08-2009, 10:04 PM | #20 |
Drives: 2007 Yaris HB Join Date: Apr 2007
mechanical model 5907
ES series has black faces, just hadda have all black |
04-08-2009, 10:10 PM | #21 |
this is the model i am getting. All Cobalts...
04-08-2009, 10:21 PM | #22 |
04-08-2009, 10:22 PM | #23 |
I almost bought Cobalt but don't remember why I chose C2 instead.
04-08-2009, 10:31 PM | #24 |
Because you wanted to look like a smurf while driving at night. That's what you told me....
04-09-2009, 09:58 AM | #25 |
04-09-2009, 10:06 AM | #26 |
when I installed the catch tank I used the screw type also, got a mix of shitty stock clips and decent clamps now.
mmmm I like the blue displays on the cobalts, mine are red lighted, my tach is like the baleful burning eye of Sauron, lol!! well I guess since this is a long weekend coming up I will finally make an effort and install my gauges, at least get all the wires pulled and so forth |
04-09-2009, 10:07 AM | #27 |
I also installed the Autometer dimmer. I was tired of driving around with my face lit up bright blue at night. My wideband LED display does not seem to dim very much although it is supposed to auto-dim.
04-09-2009, 10:11 AM | #28 |
well thing is I suck at soldering, my hands shake for one thing cuz i'm scared of being burned, plus I tend to lose patience before the iron can hot up the wire enough to wick the solder. Thank goodness for splice clips! good enough for me
04-10-2009, 12:36 AM | #29 | |
aka SDMF
heres a pic of my old greddy catch can if you need reference Last edited by staypuft; 04-10-2009 at 12:42 PM. |
04-10-2009, 01:00 AM | #30 |
Drives: 08 Yaris Sedan Join Date: Oct 2008
The pcv hoses deterioate over time and collapse. I should have mentioned i had the same problem with my yaris. I took out my intake to clean the filter and then forgot to hook back up the pcv hose to the intake after the maf sensor. Was wondering why my gas milage was crappy and how come my acceleration was poor.
04-20-2009, 04:12 AM | #31 |
Yah. I don't have room to put mine there because of the aFe intake. I may have to sell mine and fabricate a smaller one. I just read a thread where someone made a small one.
Thanks, Mike.
05-08-2009, 11:40 PM | #32 |
Drives: Yaris Base Join Date: May 2009
what is the best spark plugs to use? denso or accent? platinum or regular?
05-08-2009, 11:51 PM | #33 |
For boosted Yaris, a few of us are using NGK Iridiums, heat range 7.
05-09-2009, 12:48 AM | #34 | |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Just reading this for the first time... pre-ignition? are you sure, do you know what pre-ignition is and what causes it? I think you mean detonation? pre-ignition is when the fuel ignites on its own because of a hot spot in the combustion chamber... its caused by an air leak, too hot of spark plug heat range, poor cooling system circuilation/cavitation or carbon build up. if you enegine is suffereing from pre-ignition it will rev uncontrolably and try to continue to run after the key is shut off... Some people call this dieseling. When an engine sufferes from pre-ignition you can shut the key off, remove the sparkplug wires/coil wires and it will still run as long as its getting fuel. higher compression engines or forced induction engines often suffer from detonation (KNOCK) because the compression rates are too high or the timming is too far advanced creating too much heat for the lower octane fuel FWIW the plug color look ok but stop using Lucas in you fuel and oil Switch to a better fuel and true synthetic oil
The early bird gets the worm, but the second mouse gets the cheese. |
