Old 05-28-2009, 09:37 AM   #1
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Lightbulb NAV SYSTEM ANTENA SIGNAL BLOCKED BY TINT ON WINDSHIELD
Hey all. I have a Pioneer Avic D3, and when I had it installed back in 2007, the guy placed the GPS antena inside the car. Right on top of the dashboard. I've recently tinted my windshield and just discovered the hard way, that the tint actually blocks the GPS Satellite signal. Now, I have to somehow place my antenna outside the car in order to get signal. My question now is. Are there any ideas on how to do it, without making a mess? All suggestions are welcome!
GioBatera
Giobatera is offline   Reply With Quote
Old 05-28-2009, 09:44 AM   #2
Go under the hood through the large bushing behind the fuse panel, and then mount it to the bottom of the plastic cowling at the base of the windshield.
Old 05-28-2009, 09:45 AM   #3
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Change your tint to something that is non-metallic, or you can cut a small corner off the top or bottom of your windscreen tint to allow your GPS antenna to peek through. If your GPS supports an auxiliary connector for an external antenna, you can run a wire through your firewall and to the outside.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 05-28-2009, 10:02 AM   #4
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
The antena is meant to be placed on the outside. It has the magnetic to stick to the car. It was just placed inside instead.
GioBatera
Old 05-28-2009, 10:03 AM   #5
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
The tint is not metalic though, but it does block the signal. I was wondering maybe I could some how run the wire from the back of the unit, coming out from the hood. Question is, how?
GioBatera
Old 05-28-2009, 10:23 AM   #6
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
the glass should not block the signal enough to cause issues..
Originally Posted by xnamerxx
you nailed it sir.
Old 05-28-2009, 10:27 AM   #7
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
It actually does. I check the signal strengh and it's one bar and it shows that I'm in streets that I,m not even at. The minute I place the antena out of the window, everything works 100%
GioBatera
Old 05-28-2009, 10:35 AM   #8
cleong
cleong's Avatar
Sounds like you have all the necessary bits, well the best solution would be to go back to the guy who installed it back in 2007 and get him to install the antenna properly outside of the car. Unless you're intending to DIY.
TRD Blue brake pads
DC Sports header
Old 05-28-2009, 10:37 AM   #9
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
I don't trust the guy. He is a pig. That was the first and only time that he'll ever touch my car.
GioBatera
Old 05-28-2009, 11:02 AM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
take it to Andy
you nailed it sir.
Old 05-28-2009, 11:06 AM   #11
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
Despising the fact that he's a little too far from me, that might be my best option. At least I know that I can trust him with my ride. I'll send him a text.
GioBatera
Old 05-28-2009, 03:27 PM   #12
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
I spoke to a friend that I met thanks to TAMAGO. He works for the Toyota of Hollywood, FL and he'll do it for me tomorrow morning. I’ll keep you posted as far as how it came out.
GioBatera
Old 05-28-2009, 04:08 PM   #13
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Send a message via AIM to YarisSedan
My radio stopped getting signal after i got my tint. I think cause our rear glass has the antenna incoperated into it.
Old 06-04-2009, 01:49 PM   #14
Giobatera
Giobatera's Avatar
Drives: Yaris Sedan
All done.......thanks for all the help and MODS..Please close this thread!
GioBatera
Old 07-08-2009, 10:47 AM   #15
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
WINDOW TINT WILL HINDER THE SIGNEL STRENGTH !!! ANOTHER PLACE TO MOUNT IT IS DEAD CENTER OF BOTTOM OF FRONT WINDOW INSIDE INFRONT THE YOUR GUAGE CLUSTER THERE IN SMALL SPOT DEAD CENTER OF THE DEFROSTER VENT YOU CAN SECURE IT THERE THAT SPOT WORKED FINE FOR MY GPS ANTENNA MY SATELITE ANTENNA IS DEAD CENTER JUST BEHIND THE ROOF ANTENNA
pennyracer is offline   Reply With Quote
Old 07-08-2009, 10:55 AM   #16
pennyracer
boydstir
pennyracer's Avatar
IF YOU WANT A PICTURE JUST LET ME KNOW
antena, gps, repair
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 44 08-23-2014 03:55 PM
in dash nav system uncleyaris Cosmetic Modifications (Exterior/Interior) 1 07-03-2009 10:16 PM
Legal Windshield Tint Ideas Pitt Yaris Cosmetic Modifications (Exterior/Interior) 21 06-05-2009 12:57 PM
