Old 07-08-2009, 09:48 AM   #109
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Might be the tetanus setting in...
Old 07-08-2009, 10:37 AM   #110
Lafiro
Drives: 06 Yaris Sedan
I thought about this weeks ago and wanted to post this, but school and work and internship and other jobs are taking my life over.
Now that I see lots are doing this little trick, I will be going today to buy myself that foam.
Question is, what size diameter did you buy? Maybe home depot is a good place to buy it?
Thanks!
Old 07-08-2009, 12:44 PM   #111
n00b
Drives: Car
no need to wrap the second one , there is no point in wrapping it since the system needs to be hot on that side for the loop.
http://www.energyquest.ca.gov/how_it...nditioner.html
When the working fluid leaves the condenser, its temperature is much cooler and it has changed from a gas to a liquid under high pressure. The liquid goes into the evaporator through a very tiny, narrow hole. On the other side, the liquid's pressure drops. When it does it begins to evaporate into a gas.
I guess you should just bypass the condenser then!
Originally Posted by andaconda View Post
Man, I'm I getting confused now...
The low pressure line is for refrigerant flowing to the compressor. The high pressure line is for refrigerant flowing into the cabin.
n00b is offline   Reply With Quote
Old 07-08-2009, 02:34 PM   #112
Lafiro
Off topic, but where in the world is the part that is growing mold and causing my air to stink really bad and give me breathing problems now?
Someone please help me with that because I have to fix this issue. Since today I am free and having major problems installing my fog lights, I can not go to the dealership. Already tried calling and they are having phone problems.
Old 07-08-2009, 03:53 PM   #113
EasyDriver
Drives: 2008 Yaris Meteorite LB
funky air...
try this discussion.....http://www.yarisworld.com/forums/sho...d+cabin+filter
EasyDriver is offline   Reply With Quote
Old 07-08-2009, 05:01 PM   #114
b_hickman11
Drives: 08 Sedan
It has nothing to do with the cabin air filter.
Old 07-08-2009, 05:45 PM   #115
Henry G.
Drives: 2008 Yaris HB
Ok, with limited knowledge of the complexities of A/C system but with a brain and sense of touch this is easy: The big line (marked "L" on the fill/drain valve cap) is ICE COLD with the A/C on, the little line (marked "H" on the fill/drain valve) is hot. That tells me simply that it is THE BIG LINE that needs to be insulated as long as we agree the goal is to get COLD AIR from the A/C!
Try and argue that......
BTW I noticed a small but definite improvement from the wrapping I did yesterday so I will continue to do some more wrapping today....
Henry G. is offline   Reply With Quote
Old 07-08-2009, 06:40 PM   #116
n00b
Drives: Car
If the goal is to get colder air, you want to insulate both if possible. From the pictures posted, it looks like you can insulate the high pressure line where the exaust manifold is (that would be an important place to insulate since it's so close to a heat source).
The high pressure line should not be hot (with the exception being the line from the compressor to the condenser) or that means your condenser is not cooling the refrigerant.
http://movacs.com/How%20it%20works/index.html
Old 07-08-2009, 06:44 PM   #117
n00b
Drives: Car
basically you want to keep whats cool cooler and whats warm warmer
Then Denso failed by making a better condenser that cools the refrigerant even more!
http://www.globaldensoproducts.com/c...condenser.html
Old 07-08-2009, 06:51 PM   #118
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
n00b why dont you either leave or properly introduce yourself in the welcome forum. do you even drive a yaris? your just starting crap we dont need. all of your posts have been in this 1 thread. im sure they have a forum out there that discusses stuff you have found on google and wikipedia...
Old 07-08-2009, 07:16 PM   #119
Henry G.
Good post and diagram PK.
I just decided with that roll of tape there I would finish the job and wrap everything on the big line (notice I'm staying out of the technical argument by not naming it):
Wrapped the "can" portion of the line by taking two pieces of equal length insulation and doing the zip tie/tape thing.
Did the piece of line that runs against the inner fender, kind of a pain. I found the trick was to cut the piece to the right length, take it back off, install 2 already looped(just barely so as to leave the maximum room) on the pipe, put the insulation back on then wiggle the zip tie loops over either ends and then tighten them.
After that section this one was easy, I used tape again even though I dont think heat is a concern way up front but because I figure the engine bay heat in general is likely to harden the zip ties quickly making them brittle and breaking them, so the tape was more of a securing thing.
And this pic is from under the car, this section of pipe is easier to do most of the work from under the car believe it or not. Same thing zip tie and tape.
Old 07-08-2009, 07:35 PM   #120
n00b
Drives: Car
To answer your's and PK198105's question of driving a Yaris, I do not. I drive an Echo (which has crappier a/c than the Yaris).
I don't feel like posting in the welcome forum. I've never done that on any of the forums I am a member of.
Old 07-08-2009, 07:39 PM   #121
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Hence your user name... newbert.
Old 07-08-2009, 07:54 PM   #122
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
you all make this way too hard.
1)The cooler the hot side, the cooler the cold side, which means the cooler the air will be.
2)The cooler you can keep the cold side before it reaches the cabin, also the cooler your air will be.
The high temp loam plus high temp/fire retardant foam is what I would use too. That, or I think i've seen hi-temp split rubber tubing before.
Old 07-08-2009, 08:11 PM   #123
b_hickman11
Drives: 08 Sedan
Does anyone know the longterm effects this mod will have on the AC components? This sounds like a good mod for the time being but will this cause the dryer or the Evap or other parts to go out at a faster rate? Sounds like this mod will create more water in the air which will cause the parts to work harder. Maybe even causing an increase in mildew build up which is already an issue with the stock system.
Old 07-08-2009, 08:36 PM   #124
n00b
Drives: Car
There are no long-term effects other than a better working a/c.
Old 07-08-2009, 08:38 PM   #125
It shouldn't cause any issues. Normally with an AC system you insulate the suction side if the system is cooling only, and both suction and discharge if it is a reverse cycle system (i.e heat pump).
The Yaris's AC amplifier (ecu for the AC system) has temperature and pressure sensors to keep it from killing the compressor if the coils freeze up. Also, I don't think that this could cause the system to suddenly become so efficient that it can't dehumidify the air before reaching the desired inside temp (like a severely over-sized central air system in a house). I haven't seen the inside of the airbox, but the mold and stink issue is probably being caused by the condensate not properly draining (or maybe soaking into an insulation material within the box). This could explain why the TSB involves replacing the airbox.
Old 07-08-2009, 09:42 PM   #126
EasyDriver
pipe insulation size...
I got mine at Home Depot in the plumbing department. $1.38 for a 6 foot piece....all you'll need and then some. I thought I got the 1/2 inch ID, but I just measured a left over piece and it was 1 3/8 OD and 3/4 ID. I got the zip ties at Wallyworld, the 100 pack in the automotive area was less than $3...fortunately I didn't need a 100 though!
Good luck!
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
