Old 06-08-2009, 03:41 AM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Bypassing the passenger seat sensors!
I have read another thread that a resistor may be a way to bypass the sensors on the passenger seat.
Any ideas how to do this? More and more of us are installing aftermarket seats.
There has to be a way to keep it "ON" all the time.
fuji is offline   Reply With Quote
Old 06-08-2009, 09:48 PM   #2
I posted a response on another thread about a method that may work.
http://www.yarisworld.com/forums/sho...1&postcount=26
In JM350's thread he mentioned that unplugging the sensors will cause the SRS to get in a state that requires resetting by a Toyota tech. I don't think that is really true based on this quote from the SRS portion of the service manual:
"When the negative (-) terminal cable is disconnected
from the battery, the memory will be cleared.
Therefore make a record of the contents stored in
each system before starting work. When the work is
finished, reset each system as it was before. Never
use a back-up power supply from outside the vehicle
to avoid erasing the memory in any system."
Old 06-09-2009, 09:14 PM   #3
fuji
fuji's Avatar
Thanks for the instuctional CTScott. Has anyone tried this yet???
Old 06-09-2009, 09:17 PM   #4
I don't think anyone has.
Old 08-06-2009, 12:01 AM   #5
goku87
goku87's Avatar
Drives: Black HB
so basically if i want to take my seats out and put them back in, to avoid having to go to the dealer i just disconnect the battery?
...whats the catch? because that is waaaay to simple.
goku87 is offline   Reply With Quote
Old 08-06-2009, 06:42 AM   #6
No catch. If you don't start the car, while the seat is out, the SRS system won't even log an error code.
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
New seats and how i did it !!!! jm350 DIY / Maintenance / Service 34 10-18-2009 05:57 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 07:22 PM
PASSENGER SEAT AND THE AIRBAG LIGHTS mrrock DIY / Maintenance / Service 0 04-02-2007 09:24 AM
