Old 09-25-2009, 03:46 PM   #1
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Hmm my water pump failed again!!!! Could it be the pulley?!?!
So I just had my water pump changed less than a month ago. Now it is failed again. Could it be cause of the NST pulley? Non dampned vibration at high rpm killing the water pump? Cause i do drive my car to redline every single day. I am afraid if i take it back this time they will claim it has to do with my aftermarket parts.
Old 09-25-2009, 04:08 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I've had my NST pulley on for about 6 months and 5000 miles. No problems yet. I haven't heard of any other reported problems either. It may have more to do with the abuse (red-lining) you are giving to the engine.
Old 09-25-2009, 04:21 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Probably abuse. I've had my pulley on for over 50k miles and I'm doin fine.
Old 09-25-2009, 04:41 PM   #4
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
it's the pulley.
Originally Posted by xnamerxx
you nailed it sir.
Old 09-25-2009, 04:44 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
If that's the case, then why is this the first problem with the water pump with hundreds of thousands (if not a million) miles by everyone using the pulleys? Redlining the crap out of a car is more likely to cause stuff to break than a pulley.
Old 09-25-2009, 04:45 PM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
if you say so.
the ratio of water pump failures stock vs pulley tells the tale..
you nailed it sir.
Old 09-25-2009, 04:47 PM   #7
advocate
Drives: car
if you say so.
There are definitely quite a few people who've had water pump failures with the aftermarket pulleys.
Old 09-25-2009, 04:51 PM   #8
Astroman
Modded Moderator
Astroman's Avatar
The only water pump issues I've ever had was with the ol' '71 Ford. Any mechanics you could take it to that might be able to chime in? I just find it odd I've put over 50k miles with a full pulley setup on (not overdrive) without issue. Time will tell I suppose.
Old 09-25-2009, 04:55 PM   #9
Astroman
Modded Moderator
Astroman's Avatar
What about the ratio of people who redline their engine? Again that is also the other factor. And if the shop didn't install the last one correctly that could lead to premature water pump failure.
It might be worth it to run with the stock pulley for a while too, since they're in there anyway it shouldn't be a big deal.
Old 09-25-2009, 04:56 PM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
belt might be too tight..
Old 09-25-2009, 04:56 PM   #11
supmet
Drives: 2007 4 Door Yaris
lol @ the denial.
Guys... if aftermarket pulleys were a 100% win/win situation, we would have lightened pulleys stock.
Think about it.
Old 09-25-2009, 05:00 PM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
i've redlined my xA every day for 70Xthousand miles and never had a water pump (or any other) failure. stock pullies. redlining has nothing to do with it.
you nailed it sir.
Old 09-25-2009, 05:04 PM   #13
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^+1
74k miles, redline a lot, stock pullies
Old 09-25-2009, 05:04 PM   #14
supmet
trini_performance has beat the hell out of his yaris for 350,000+ miles and is on the original water pump
Old 09-25-2009, 05:06 PM   #15
Astroman
Modded Moderator
Astroman's Avatar
72k miles, redline a lot, aftermarket pulleys.
I'm just saying don't be so quick to blame the pulley. There COULD be other factors.
Old 09-25-2009, 05:06 PM   #16
Astroman
Modded Moderator
Astroman's Avatar
He also has been using an aftermarket pulley since 150k.
Old 09-25-2009, 05:12 PM   #17
posaunemeister
Drives: 2008 Yaris S LB - MM
The denial comes from ignoring the blatant admission of redlining the car everyday. Redlining DAILY will definitely do some damage under the hood. If your car was designed to cruise at 6/7/8 RPMs, then there wouldn't be a red line, period. I'm sure you've been doing some serious damage to your engine, especially considering that you most likely have stock (economic) internals. I don't see how anyone can argue in favor of redlining and against an aluminum pulley that is only 10% less than the stock pulley in circumference!
posaunemeister is offline   Reply With Quote
Old 09-25-2009, 05:14 PM   #18
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I personally think it has to do with installation of the pulley. Check the belt it may be slightly misaligned or too tight.
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
bye bye water pump cali yaris Performance Modifications 29 01-03-2009 05:06 PM
