Old 12-07-2006, 10:23 PM   #1
eflb55
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US)
Component or coaxial speakers?
I've heard that component speakers sound better because the tweeter is not near your feet but is mounted farther up. I can understand that speaker placement will make a difference but how large of a difference is this.
This is what I'm looking at for front speakers in my sedan:
Kicker coaxial $100
http://www.circuitcity.com/ssm/Kicke...oductDetail.do
Kicker component $200
I really don't want to spend $200 on my front set alone and would like to get the coaxial speakers and I'm just wondering if getting the component is really worth it.
eflb55 is offline   Reply With Quote
Old 12-07-2006, 10:50 PM   #2
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
^^^I've heard the same thing, and I have component speakers in the front and its really nice! There ideal to separate the highs and lows, so you can still hear the people's voices with the beat meaning its not muddy. Also like you mentioned it creates better sound imaging so it fills the car better and you can hear it in full-so nice! Its also very crisp, clean and clear and when it hits the highs its amazing! Of course it depends how lound the stereo is. I beleive most people get components for the front the coaxial for the rear. I think I have three ways in the back of my car, sorry I'm not too knowlegable on the names. Good luck!
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 12-07-2006, 11:14 PM   #3
ChinoCharles
Drives: LB
First of all, you can get those components for half that price on Ebay. $200 for Kicker components is absolutely ridiculous. They're good, but they aren't worth 200 bones.
http://search.ebay.com/search/search...e=kicker+ks6.2
If you're looking at $100 components, you might as well just get two sets of components. They're going to sound better, and you'll only be spending 50 bucks more than getting a set of components and a set of coaxials. Since you have a sedan you can mount the tweeters right up below the rear window. It'll sound sweet.
Old 12-08-2006, 01:24 AM   #4
bigsky2
Cousin Vitz
bigsky2's Avatar
$200 for a pair of Kicker components is ridiculous, yes.
You can get a pair of entry/mid range Focals for that price, and they blow away any component setups by far, if powered by the right amplifier.
Components will generally sound better.
If you have the coin, try to get 3-way component speakers as they will bring out richer sound than 2-way comps.
One tip I strongly suggest: Experiment with your tweeter locations prior to physically mounting them.
Old 12-08-2006, 07:18 AM   #5
punch
punch's Avatar
Kicker coaxial $100
I went with componants, it was a tight fit for the crossover in the door but worked out, heres a few shots of the 1st, install, i then cleaned up the wiring..
punch is offline   Reply With Quote
Old 12-08-2006, 05:02 PM   #6
eflb55
its EF LB 55
Ya thats where I thought the tweeter would best fit in the front. Only probably I have with that is that its no better than sticking a sign on my car that says "I have a pretty good stereo system. Steal me!" Not like I live in a bad neighborhood though. I'm having trouble finding any 3-way components for 6.5 on eBay but I'm pretty sure ill just spend 80 or so on the 2-way kicker components if I can't find a reasonable 3-way.
Old 12-08-2006, 05:36 PM   #7
punch
punch's Avatar
tint! you don't have room for 3 way components in the sedan door.
Old 12-08-2006, 06:49 PM   #8
eflb55
its EF LB 55
I don't think they make component speakers for 6x9 for the rear of my yaris.
So what I'm leaning towards is going all infinity kappa with first buying just my front speakers (60.7CS, two-way component) and then later my rear (693.7I, 3-way) and an amplifier(figure that out later). This should run me about 100 each set on eBay from the looks of it.
Old 12-08-2006, 09:33 PM   #9
ChinoCharles
Drives: LB
You could always make a bracket with a 6.5" slot in it to screw into the stock 6x9 location. Bigsky2 drew up a spacer somewhere... I'm too lazy to try and find it though. He will know, or just search it out.
Old 12-09-2006, 12:24 PM   #10
eflb55
its EF LB 55
is the extra work really worth putting a 6.5 3-way component over a 6x9 3-way coaxial?
Old 12-09-2006, 12:30 PM   #11
ChinoCharles
Drives: LB
Is is really worth the extra work to do anything? You know, screw it, lets all drive stock cars. This is too difficult.
Old 12-09-2006, 04:37 PM   #12
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Kappas are good and all, but they don't make the 4ohm versions anymore, just so you know, so if you were planning on wiring up 4ohm speakers, get References or Kappa Perfects, current Kappa models are 2ohm only. And if you're already shelling out the extra coin for Kappas... you may as well just get the Kappa Perfects, they're worth it.
paultyler_82 is offline   Reply With Quote
Old 12-11-2006, 09:40 PM   #13
eflb55
its EF LB 55
ya i was wondering about that. I'm afraid if I get the 2ohm speakers for the front and attach them to my internal amp (50x4) that I might overheat it. I found kappa perfect new on ebay for 180 but I really don't need that much power.
Call to those who adapted 6.5" speakers to rear of Liftback W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 9 03-10-2009 10:06 PM
Can I install these speakers to the front and rear of my liftback? W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 33 02-25-2009 02:23 PM
Stock 6 disc MP3 deck + speakers for sale!!! chino_potato Items for Sale by private party 16 02-05-2009 07:27 PM
Matching up right speakers for 4DR Yaris.... ohms match up? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 7 09-13-2006 11:12 PM
how to install back speakers? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 4 09-10-2006 09:29 PM
