Old 11-01-2009, 08:11 PM   #1
ob1bogie
ob1bogie's Avatar
Drives: bb hb
squeek
I have squeek coming from the rear brakes when i release my pedal any ideas
ob1bogie is offline   Reply With Quote
Old 11-01-2009, 08:20 PM   #2
YAR1S
YAR1S's Avatar
has it been raining lately? my brakes squeak when they are wet.
-Jen <3
Old 11-01-2009, 11:01 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Need more information. Are you moving or at a stop? Is it a chirp or a long squeek? etc...
Old 11-05-2009, 12:43 PM   #4
ob1bogie
ob1bogie's Avatar
Drives: bb hb
the brake pedal sqeeks from the back of the car when i release the pedal moving stopped the only time it doe not sqeek is when the parking brake is engaged thanks
Old 11-05-2009, 11:16 PM   #5
Lafiro
Drives: 06 Yaris Sedan
Does it make the same sound if you take the e-brake and lift it up and down fast/all the way pretty much(dont force it).
If so its two things: Its an indicator to tell you your shoes may be worn down.
But most of all, your drums need to be cleaned, and the star wheel needs to be clicked about 3-11 times to adjust the spacing of the shoes against the drum.
Then the noise should go away, but remember you probably need new brake shoes as well.
Someone else may chime in on this.
squeek squeek firefly1_0 General Yaris / Vitz Discussion 2 04-16-2007 02:02 PM
