Old 02-10-2010, 07:58 AM   #19
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
The point remains the same. It's wherever the car stops making power. I can't imagine a build on the 1NZ that would require 8k or 9k rpms, so the question doesn't hold much relevance for me.
besides camshafts, you better have springs and some other head work done to access higher rpms safely.
Could you share your opinion what do you mean by better springs? or else what springs do you recommend
Old 02-10-2010, 11:47 AM   #20
better springs = stronger or "high pressure" springs
I don't have a recommendation, I have stock springs and I'm happy with my results so far. I see no need right now for higher revs - the car doesn't make more power up there.
Old 02-10-2010, 05:27 PM   #21
Parmas
Parmas's Avatar
In the microimage forums you mentioned in your thread (on last page 7) that art used stronger springs. Are you sure they are stock?
Old 02-10-2010, 05:52 PM   #22
yep, they are stock. I was wrong. :(
Old 02-10-2010, 07:02 PM   #23
even richard holdener's setup peaked around 6000rpm
Old 02-10-2010, 09:12 PM   #24
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I can almost guarantee that you're starting to float the valves past 6000 RPM. With 20 psi of boost pushing them open, plus the high revs and the fact that they are pretty soft to start with.
Old 02-11-2010, 05:41 AM   #25
Parmas
Parmas's Avatar
I can say that many owners who built a 1NZFE focused more on the bottom end (pistons and rods) which it's the right thing... but when planning beyond certain power and boost you can't leave a stock head pure and plain!
What about a Top End build? Is there a secret for the ultimate powerband of a 1NZFE?
Old 02-11-2010, 01:47 PM   #26
it's no secret. port and polish, then work on valves, then work on cams. Cams are tricky with VVT-I though, in my experience.
Old 02-11-2010, 07:21 PM   #27
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Basically, the camshaft that you run depends where the power band will be in the rev range.
Ideally, you choose your camshaft based on the intended purpose of the vehicle and where abouts you want the power band to be in the rev range, then select valve springs (and sometimes valves) to suit, and then size your turbo, intake, exhaust and intercooling system accordingly.
In theory, the design of the 1NZFE does not suit really high revs due to the bore to stroke ratio.
If using stock cams, then the factory redline (or slightly higher if it helps with your gear change points) will suffice.
rob323 is offline   Reply With Quote
1NZFE K1 by Carrillo Rod interest list xBoosted Forced Induction Forum 20 01-20-2009 02:51 PM
EVERYONE PLEASE STAY SAFE! Shroomster Off-topic / Other Cars / Everything else Discussions 5 01-01-2009 05:47 AM
CEL blinking during rev limit hit. ddongbap General Yaris / Vitz Discussion 2 10-01-2007 02:10 AM
Hyper Rev: Vol# 108 Vitz (No. 3) **IN STOCK & READY TO SHIP** KamiSpeed Sponsors Classifieds Area 1 03-03-2007 01:50 PM
