Old 02-01-2010, 01:26 AM   #1
604yarisrs
Drives: 09 Yaris RS hb
Disabled drl and installed hids and now no fogs...
Today I installed my 6000k HID's, then found out about the drl flickering problem. So i disabled my drl module but that made my fog lights not work. So I was wondering how to keep my drl module connected and have my parking lights as my drl's.Please help!! I got 6500k led fog lights and cant be used!! hahaha
604yarisrs is offline   Reply With Quote
Old 02-01-2010, 10:01 AM   #2
I can get a relay wiring harness for your HID's that will let them work off your battery as the DRL's...or a set of capacitors that will cancel the DRL's
either one for $30 shipped to your door.
the reason the fogs stopped working is that in the RS, the stock fogs are routed thru the DRL module....and DO NOT run the HID's on the lower wattage of the DRL's, it will kill the ballasts....
PM me if you're interested in the relay harness or drl cancellers....
Old 02-03-2010, 05:41 AM   #3
Jerkratt
Jerkratt's Avatar
all u have to do is ground out the fog light wire from the drl relay harness... ill go outside tomorrow if its not to cold and take a pic of what im talking about
"It hurts more when its wet"
Old 02-04-2010, 10:26 PM   #4
604yarisrs
sooo u have the relay harness disconnected but juz take one of the wires from the connector and ground it?
thank you jerkratt plz post pics soon ! i want my fogs!! hahaha
Old 02-04-2010, 10:32 PM   #5
Jerkratt
Jerkratt's Avatar
First thing when I wake up ill go outside and snap pics.
Old 02-04-2010, 11:16 PM   #6
You can either ground the beige wire of the headlight stalk connector shown in this picture (ignore the park light label):
Or you can ground the other side of the beige wire at the DRL connector.
Old 02-04-2010, 11:23 PM   #7
Jerkratt
Jerkratt's Avatar
thanks i was gonna check the color of the wire but u told him if u ground the brown/baige wire
Old 02-05-2010, 09:11 PM   #8
604yarisrs
thanks! do u also know where the parking light positive wire is because i know which wire my drl is and if i juz connect my drl to my parking light instead of the low beam then all my problems are fixed. Since im in canada its illegal to have no drl, soo i was hoping to make my led peanut bulbs as my drl lol Thank you again! you are soo much help for me!
Old 02-05-2010, 09:22 PM   #9
Old 02-14-2010, 11:32 AM   #10
hirme
Drives: Yaris HB '07
I don't mean to hijack your thread but I have a question concerning DRL and HID.
I'm in Canada so DRL are mandatory. The way I understand it is if I go HID, I'll need to turn on my headlight during the day. Will this cause the HID light to go bad within a few months/years or they will still last long enough to not care about?
TIA
hirme is offline   Reply With Quote
Old 02-14-2010, 12:26 PM   #11
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Well in general the ballast for HIDs tend to last about 1.5 to 2 years if you run them on daily.A lot of guys that have HIDs on Scionlife including my self just replace them about every 2 years,most sets are under $100 for ballast and bulbs.
Tags
drl, hid, parking light
