03-16-2010, 08:03 PM | #1 |
Drives: '09 Yaris Sedan Join Date: Mar 2010
Big 3 Upgrade in '09 Sedan! (w/pics)
Just did my Big 3 Upgrade in my Yaris. Here are some pics!
The engine bay is dirty I know, but I have to drive 4 miles round trip on a dirt road everyday to get home
Pioneer
Ascendant Audio Sundown Audio DC Power Engineering Knukoncepts Fosgate Stinger |
03-16-2010, 09:31 PM | #2 | |
Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
for your audio system? lol Im clueless.
-Jen <3 Quote:
03-16-2010, 09:39 PM | #3 |
Correct! I needed it bad as I plan to run almost 3500 watts of car audio!
Pioneer
03-16-2010, 09:47 PM | #4 |
Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
I did mine last week. I still have my factory stereo now but that will change in a few months. I only plan on 1000 watts or less but I think this is a good idea no matter how small of a system.
03-16-2010, 10:22 PM | #5 |
Yes sir! My 300 amp DC Power alternator should be going in within the next 3 weeks!
Pioneer
03-16-2010, 10:25 PM | #6 |
Pioneer
04-08-2010, 07:54 PM | #7 |
Put in a Fosgate fuse Block, and Fosgate Wire all around!!!
Pioneer
04-08-2010, 07:59 PM | #8 |
Drives: 08 Yaris Sedan Join Date: Oct 2008
Looks good i plan to do this soon as well im too lazy though ive had the wires sitting in my closet for months
04-09-2010, 01:49 AM | #9 |
Roadrunner Jr.
I know this may sound like a trollish question...but why in the name of all that is holy do you have the fuse on top of the engine cover? Did you just run out of wire? Stick that on the firewall...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
04-09-2010, 02:22 AM | #10 |
Maybe he'll redo it after he gets the Monster Alternator
Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
04-09-2010, 02:28 AM | #11 |
thats some chunk cable mate
04-13-2010, 11:03 PM | #12 |
this may sound like a trollish answer...but I kind of like it there.
Pioneer
03-27-2012, 11:38 AM | #13 |
Drives: 2009 yaris sedan Join Date: Apr 2011
is the big 3 needed for a 300 watt mono amp? (just the one amp)
03-27-2012, 12:35 PM | #14 |
It wouldn't hurt.
Basically if you have an extra 25 bucks go for it. Even then you could probably build your "Big 3" kit cheaper. 4 gauge wire would work or you can prepare for a bigger system and use 0 gauge. Knu Konceptz KCA 4 gauge is rated @ 100 amps and is 95 cents a foot or check them out on ebay. I'll post where I ordered some wire from later on. And post some connectors.
Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 Last edited by _S7V7N_; 03-27-2012 at 03:52 PM. |
05-15-2012, 11:50 AM | #15 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
So, if I'm reading correctly, I can actually replace the stock cables, rather than add to them? Say I went with a low gauge (1-2) and took out the stock cables (alt->chassis/battery, battery->chassis, right?) and replaced it, that'd have the same effect, correct? Getting more info from the12volt.com, btw.
05-15-2012, 12:47 PM | #16 |
Add don't replace. Your cpu won't like it if you replace
05-15-2012, 02:15 PM | #17 |
Yaris323
Drives: 09 Sedan Yaris 06 Ford Mustang Join Date: Mar 2009
05-15-2012, 10:59 PM | #18 |
Only Happy When it Rains
wow do want to be a jerk or just a loser? your post makes you look like both and more.
Colin Chapman disciple |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
The Big One upgrade | fuji | DIY / Maintenance / Service | 2 | 02-15-2009 02:37 AM |
So how do you like the BIG SMILE on the 07 Sedan???? | Ziv | General Yaris / Vitz Discussion | 3 | 02-03-2006 11:12 AM |
