Old 05-06-2010, 03:45 PM   #1
i<3yaris
MPG Hog
Drives: 2007 Yaris Sedan
Do I have ABS?
I have the 2007 Sedan Base with Power Package. Does the power package provide ABS, or was that a separate option? I know the for sure way of finding out, but I would rather not
i<3yaris is offline   Reply With Quote
Old 05-06-2010, 04:00 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
We've got a 2007 S Sedan with Power Package. No ABS. It was a separate option, I believe, and quite rare. It became standard on the 2009 models.
Old 05-06-2010, 04:06 PM   #3
i<3yaris
MPG Hog
Really? Because I did some research between the time I posted and when you replied and I found the official Toyota .pdf for the 2007 Yaris and it states that the power package for the Sedan and S Sedan included ABS with EBD. Weird.
Old 05-06-2010, 04:08 PM   #4
b_hickman11
Drives: 08 Sedan
2007 Yaris did not have ABS
2008 ABS only with Power Package
2009 Standard on all Yaris's
b_hickman11 is offline   Reply With Quote
Old 05-06-2010, 04:53 PM   #5
yarrr
Drives: 07 sedan
Where are you guys getting this information about ABS being rare? Its an option, but I know for a fact there were yarii at the dealership with ABS when I bought my yaris in early 07... and iirc every S had ABS.
Its not that scary finding out the "hard way" just get some good open road and press as hard as you can at 45. You can let up the second they start squealing if you don't have ABS, just keep the wheel steady.
yarrr is offline   Reply With Quote
Old 05-06-2010, 08:03 PM   #6
i<3yaris
MPG Hog
I have confirmed that my 07 Yaris does indeed have ABS. I took it for a little drive :)
Old 05-06-2010, 09:30 PM   #7
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
Lightbulb
easy way is to look under the hood
trace the b-lines off the b-master
if you see a box with like 4 steel lines coming off it you have ABS
or turn the key on acc there is usually a light (ABS) on display
OTA'sTOY is offline   Reply With Quote
Old 05-06-2010, 11:24 PM   #8
BailOut
Steals terrorist's lunch
BailOut's Avatar
Here's a weird one for ya... I have the base model 2007 LB and it definitely does not have ABS (nor do I need it). There is no indicator light, no "box" in the brake line system, no pedal pulsations when I brake hard.
Yet when the 2 insurance companies I've used have pulled up the VIN it shows that the car does have ABS, and they each have given me a discount for it even after I've told them that it doesn't have it.
- Brian
Share the Road
Old 05-07-2010, 12:03 AM   #9
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
+1 with my insurance company, and still I lock-up sometimes through canyons lol
ABS LIGHT & E BRAKE LIGHT rossman DIY / Maintenance / Service 5 02-25-2010 11:09 PM
Adding ABS to a Yaris tadc Performance Modifications 1 02-14-2010 03:56 PM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
ABS....Again~~ MeggiemobileSFLA DIY / Maintenance / Service 11 04-03-2007 09:12 AM
ABS Virgin!!! yaris-intuit General Yaris / Vitz Discussion 23 11-29-2006 12:49 PM
