Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Africa
Old 08-25-2010, 07:13 AM   #1
kaijyu
kaijyu's Avatar
Drives: 2010 YR 5 door manual
Multi-Informational Display in SA
Hello all the SA people. I have recently purchased a Yaris YR, and have noticed that the Multi-Informational Display does not operate. Only as a clock. In my owners manual, it states that the 'MID' only functions in SA. Just wondering if we can explore and differences to see if this can be a simple resolution.
I have attached a picture (from one of the other forums) which shows the clock on the left side, along with the greyed areas that don't function in Australia.
Any assistance would be appreciated.
kaijyu is offline   Reply With Quote
Old 08-25-2010, 07:58 AM   #2
The additional functions can only be enabled by changing the programming of the processor within the cluster. There's no way to simply enable them.
Old 08-26-2010, 08:01 AM   #3
kaijyu
kaijyu's Avatar
Given the posts I've read thus far, I believe you. Because you probably still have that Australian one on your bench!
By all accounts, your the man in this forum who'll know.
It doesn't meant that I want to believe you! I must have some hope!
Old 08-26-2010, 08:35 AM   #4
kaijyu
kaijyu's Avatar
Accorinding to one of your old posts:
http://www.yarisworld.com/forums/sho...&postcount=214
It could be reasonably simple...... maybe for you!
Old 08-26-2010, 09:31 AM   #5
That turned out to be a bust. Once I had access to both types of clusters, I found that the cluster is either programmed for it or is not. There is not way that I've found to be able to turn it on.
Old 08-29-2010, 07:52 AM   #6
kaijyu
kaijyu's Avatar
So, what you are saying is, if I want this to work, I should purchase a South African cluster!
Further, do we have a picture of a South African cluster in the forum?
Old 08-29-2010, 03:32 PM   #7
SA or JDM.
Old 08-29-2010, 10:37 PM   #8
kaijyu
kaijyu's Avatar
SA or JDM.
I assume that is the Nippon version?
Old 08-30-2010, 07:04 AM   #9
Correct JDM = Japanese Domestic Market.
Old 08-31-2010, 04:08 AM   #10
kaijyu
kaijyu's Avatar
Seems SA option is dead. Japanese option is possible. Shall move to Asia zone and start again. Thanks CTScott.
