![]() ![]() Drives: 2 Yaris Hatchbacks Join Date: Dec 2006
Anybody investigate adding heated mirrors to 07?
I could see the benefit of adding heated mirrors to my 07 hatch. In the US, there are finally the OEM replacement parts available for the mirror elements themselves. Has anyone bought these and played around? Looks like the mirror itself is a snap replacement part, but would the heated ones be a direct replacement, except for wiring? Anyone have the wiring diagram for how they are hooked into the rear defroster circuit on a 2010 model? Thanks, winter is approaching!
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
PM me your email and I can send you a copy of the EWD for the mirror heater wiring. |
![]() ![]() Drives: '07 Yaris 5dr HB Join Date: Aug 2010
I've thought about adding heated mirrors as well. Especially this morning when I was driving to work and my mirrors were all frosted up. I too have an '07 HB. Would this be a simple install? Do the heater elements mount behind the existing mirrors, or do I have do get new mirrors with elements already installed?
#4 | |
#5 | |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
so if I have 2010 hatchback then the wiring should be already there right ?
but how will be the heaters switched on ? wouldn't be needed some switch ? how much cost the mirror plate with heaters ? what about the installation is it hard ? |
Do a web search for "heated mirror kit" and you'll find plenty.
Here's a DIY that someone did for a Tacoma, using motorcycle grip heaters. It shows nicely what's involved in pulling the mirrors apart (they Yaris mirrors are mounted the same way), running the wires through the door, and wiring them. http://www.tacomaworld.com/forum/2nd...d-mirrors.html |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
A spray bottle of De-Icer cost me $2.50 at walmart this morning. I believe I also had to pay tax.
#9 | |
Winterizing
Drives: 2010 Toyota Yaris Hatchback Join Date: Oct 2011
warranty
33.7 mpg in PA ![]() |
![]() ![]() Drives: 2009 yaris 4dr hb Join Date: May 2010
Sorry FOR Reviving But I just opened my door to install my led side mirrors for my 09 hb and I saw that my mirrors are already hooked up with one... CTScOTT do you know where I can hook this up just by using my defroster switch?
If they are present, they are probably already hooked up and they do work with the defroster switch. I think on other discussions on here, others mentioned that 09+ Yaris in Canada have the mirror heaters.
hello ctscott, donesnt seem hooked up tho... would you happen to know wheere the terminals for the back window is hooked up on? so i could just splice and tap to that?
#13 | |
That violet wire goes to pin 11 of Connector 4M of the under dash fuse panel. From there they go through the 10A ID/UP/MIR HTR Fuse in the fuse box under the bottom of the dash. That fuse is fed from the defroster relay and at that point (internally to the under dash fuse panel) is connected to the rear window defroster (which connects via black wire to pin 2 of connector 4F). ![]() Fuse Panel - Rear.jpg Fuse Panel.jpg
Not quite a noob
Sorry to res. Scott, would it be safe to connect mirror heaters directly to the line feeding the defrosters? Or are the defrosters fed from a different source
It would be fine to hook them up with the defrosters, as that is how the OEM ones are wired. Mirror heaters are very low wattage heaters.
Not quite a noob
Great, thanks Scott - going to attempt this when I have time
Not quite a noob
Oh, one more thing: could I ground it to the power mirror wires? That way I only have to run one wire through my door to the electrical panel right?
Modded Moderator
I'm putting this mod on the to-do list, behind the supercharger, gauges, amp, HID conversion, wiring the fogs, and mounts to move the passenger seat further back.
Heated Side View Mirrors | goku87 | DIY / Maintenance / Service | 27 | 01-26-2016 05:23 AM |
Unlinking heated side mirrors / rear defrost | Alezius | DIY / Maintenance / Service | 9 | 11-03-2010 01:29 PM |
heated mirrors on 09 model? | DOMAV | General Yaris / Vitz Discussion | 34 | 10-27-2009 04:13 AM |
Replacing manual mirrors with powered plz help | MikeB | DIY / Maintenance / Service | 0 | 05-27-2009 09:55 PM |
Will '09 Heated mirrors fit on an '08? | goku87 | DIY / Maintenance / Service | 1 | 11-17-2008 05:39 PM |
