Old 09-23-2010, 12:56 PM   #1
Kaya B.
Drives: Yaris
Cruise Control on 2010 Canadian Manual
Hello,
I want to install Cruise Control on my 2010 Canadian Manual.
I want to use original parts. My car has electronic tachometer.
What is the procedure for finding the right parts for my car?
I looked at PeteZNY's topic at http://www.yarisworld.com/forums/sho...cruise+control
But i don't know does the same parts work for me.
I looked at my tachometer with a bright light. I can see the lights for the accessories i never used. (they don't light but they appear under bright light) but I couldn't see the cruise control lights.
I looked at CTScott topic for Cruise Control FAQ at http://www.yarisworld.com/forums/showthread.php?t=25515 but i'm not sure if cruise control works for me because i couldn't find the cruise control lamp.
I'll be glad if you help.
Thanks.
Kaya B. is offline   Reply With Quote
Old 09-24-2010, 10:33 AM   #2
Kaya B.
Drives: Yaris
Hello again,
I found 84632-34011 on ebay, and just ordered it.
I couldn't find other parts at the moment. I'm searching.
Old 09-24-2010, 11:21 AM   #3
Kaya B.
Drives: Yaris
Hello,
I just disassambled my tachometer to see the lights but I don't have the cruise control lights!
my tachometer photos are attached.
and I'm attaching the connector photos.
Old 09-24-2010, 12:30 PM   #4
It definitely won't work on yours.
Your car is not a Canadian one - Based on the wiring and the cluster, I would suspect that it is a European one.
Old 09-24-2010, 12:39 PM   #5
Kaya B.
Drives: Yaris
Hello,
I bought it brand new. It is the LS package. Built for the Canadian market and sent to Turkey. Differences from Turkish model are; heated seats, bluetooth, manual rear windows, daytime running lights and no start&stop system.
I'm sure it is Canadian. And I've already purchased the cruise control stalk :(
Also; authorized dealer asks for 250$ to install cruise control.
Old 09-24-2010, 01:33 PM   #6
Canadian market does not get the digital cluster.
Old 09-24-2010, 01:38 PM   #7
Kaya B.
Drives: Yaris
oh :(
so what shall I do?
Old 09-24-2010, 01:45 PM   #8
Originally Posted by Kaya B. View Post
oh :(
so what shall I do?
Outside of my knowledge and experience. This is where I go
Sorry
Old 09-24-2010, 02:39 PM   #9
If you PM me your VIN, I can run it through the international EPC and figure out what market your car is actually from, but just having the digital cluster and the wiring for steering wheel audio controls means that your ECM does not have the cruise control functionality.
Old 09-24-2010, 03:23 PM   #10
Kaya B.
Drives: Yaris
thanks all.
I learned that the LS package cars came especially digital cluster because there were no analog clusters in Turkey.
they came with another package in the half of 2010 called terra sporty
Old 09-24-2010, 03:39 PM   #11
henry33
Drives: yaris1.33
Scott will check also my vin ? please
henry33 is offline   Reply With Quote
Old 09-24-2010, 03:44 PM   #12
thanks all.
OK - I received your PM with you VIN.
Your Yaris was made in France (in the TMMF plant) in December of 2008. It is a European Terra Type. So, no easy cruise control for you.
Old 09-24-2010, 03:44 PM   #13
Sure - PM me your VIN.
Old 09-24-2010, 03:50 PM   #14
Kaya B.
Drives: Yaris
thank you Scott.
I'll research what i can do.
any advices where to start?
Old 09-24-2010, 03:57 PM   #15
thank you Scott.
Check out the link below. This Belgium based company makes an aftermarket CC for European Toyotas:
http://www.el-pas.com/products.htm
Old 09-24-2010, 04:00 PM   #16
Yours, like Kaya's was built in France at TMMF, and is a Terra Type. The build date on yours is January, 2010.
Old 09-24-2010, 04:01 PM   #17
henry33
Drives: yaris1.33
where or how you check this ?
Old 09-24-2010, 04:02 PM   #18
henry33
Drives: yaris1.33
in other words no cruise control
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
