Old 02-12-2007, 10:05 AM   #1
mrrock
Drives: yaris 2dr hatch
Suspension alignment after new springs?
I've put tanbe NF's on and I'm about to have an alignment. How much will the drop have changed the alignment? can the alignment be put back to factory specs or close?. also, is there any alignment for the back? I notice a little bit of negative camber.
mrrock is offline   Reply With Quote
Old 02-12-2007, 10:12 AM   #2
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
for the rear there's no worry, it doesn't have toe-in adjustment, and the camber itself doesn't affect tire wear. for the front wheels, NF's will change somehow the toe-in. not dramatically, but it will be a good idea to have it checked if you intend to keep the springs all year around. In fact, this is true for every aftermarket spring available for Yaris. The NF's and the Eibach give the smallest drop available (about 1'').
hystria is offline   Reply With Quote
Old 02-12-2007, 12:52 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
Any time a suspension component is changed you should get the alignment done.
Old 02-14-2007, 02:03 AM   #4
El Jefe
Drives: 07 yaris s sedan
i have nf's on my sedan and i had to adjust my toe a little bit, but i didnt adjust the camber and after about 6k miles i have no abnormal tire wear isssues at all.
2007 S Sedan, NF210's, 5% rear windows, 35% front two, Sirius S50, 15" black konig heliums
El Jefe is offline   Reply With Quote
Old 02-14-2007, 10:29 AM   #5
mrrock
Took it into the dealer yesterday and had alignment done. the said they adjusted the toe in but they said that they also adjusted the toe in the back.
I didn't think you could adjust the toe in the back: are they just blowing smoke up where the sun doesn't shine?
Old 02-14-2007, 01:05 PM   #6
Black Yaris
der Zeck
Toe can be adjusted in the rear with shims
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
