Old 10-31-2010, 09:18 AM   #55
p123456789
Drives: 07 lb jeep tj
Originally Posted by N3misiS View Post
Well, I can surely add to this list,
On about 31 000 the gearbox broke, the final dive and basiacly all the gears where cracked and in pieces, this happened with no warning,, no funny sounds nothing.
I replaced it my self as my car had a light accident on the driver door and Toyota refused
to help.
And about 3 months ago the motor dropped 2 exhaust valves on Cyl no. 3 and and I have replaced the motor.
Services gets done on every 10 000 Km as I do these my self, I use Magnatec Castoll,
everything else from Toyta Parts. and the motor gave in on 71432Km
Once again, it broke with no warning, I was in middle of 1st gear about 20Km\h and it broked.....
I love Toyota! but if this keeps hapening I will not buy another toyota again!!!!!!
No issues with water Pumps or Electical issues at all either.... ever
you must be really hard on your car if you have ruined two transmission and an engine. can't blame the car for beating it to death.
p123456789 is offline   Reply With Quote
Old 02-17-2011, 04:33 PM   #56
posaunemeister
Drives: 2008 Yaris S LB - MM
I just looked under my hood and there was dried-up pink splash/streak under my hood and pretty much covering every component near the belt. I will call to see if when I can have this pump replaced. I have an '08 Yaris Liftback.
posaunemeister is offline   Reply With Quote
Old 02-19-2011, 02:17 PM   #57
Klink10
Klink10's Avatar
No mods? If so I feel for you and hope the dealership comes thru.
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
