Old 04-25-2011, 12:23 PM   #181
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Originally Posted by SKurj View Post
Excuse my expletives... but my local dealer quoted me $700 for an aftermarket cruise today...
Guess I will be trying my hand at this DIY.....
$700? ouch, though believable if you've got a 2004 Echo. The Yaris uses drive-by-wire so the cruise control is entirely computer controlled. With the Echo they'd need to install mechanical controls to maintain the throttle position.
Mine was just a hair over $500 for the third party Rostra cruise which I had removed in the fall when there was an optional recall.
I don't think this DIY will work for you. If you know what you're doing you could probably find the Rostra kit online far cheaper than the dealer wants but you'll be getting your hands dirty installing it.
teddy is offline   Reply With Quote
Old 04-25-2011, 01:28 PM   #182
SKurj
Drives: 09 Yaris 3dr HB, BRZ
No my 04 has cruise already, installed by toyota for $300 in 2006. This time its my 2009 5spd 3dr.
SKurj is offline   Reply With Quote
Old 04-25-2011, 01:49 PM   #183
teddy
In that case, join the club with DIY cruise!!
Old 04-25-2011, 03:10 PM   #184
liam6200
Drives: 2010 Yaris 1.4d
hi, im from the uk, i have a 2010 yaris 1.4 diesel, would this work on my yaris?
liam6200 is offline   Reply With Quote
Old 04-25-2011, 03:19 PM   #185
No. Only USDM Yaris with the 1.5L engine have the cruise control functionality built into their ECM.
Old 04-25-2011, 03:29 PM   #186
liam6200
ok thanks anyway
Old 04-27-2011, 08:03 PM   #187
CB900F2
Drives: 08 Sedan
Photos of my OEM CC install
Originally Posted by CB900F2 View Post
Teddy and all.. Use the template that comes with these installation instructions for the OEM CC installl.
I’ll take some pictures of mine and will post then shortly...
Old 04-27-2011, 08:11 PM   #188
teddy
Is that with the OEM steering wheel cover (with the pre-cut hole?) That's specifically what I'm looking for.
Old 04-27-2011, 08:16 PM   #189
CB900F2
Drives: 08 Sedan
Hi Teddy.. That is the OEM steering wheel cover, but I drilled the hole using the template.
Old 04-27-2011, 10:05 PM   #190
Here's a picture of one with the OEM stalk hole.
Old 05-04-2011, 03:39 AM   #191
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Can someone please tell me what the functionality is of the single OEM wire/pin that plugs into the D3 connector on the steering column? I ask because I need to replace this connector but want to know what I'll be unhooking exactly, once removed.
Thanks.
white_rice is offline   Reply With Quote
Old 05-04-2011, 07:31 AM   #192
Thanks.
The black wire is for the horn.
Old 05-11-2011, 12:52 PM   #193
SKurj
Ok so my steering wheel cover came in today. I followed all the steps, and kept saying to myself.. too good to be true... too good to be true....
Everything back together, start the car.. airbag light won't turn off... uh oh here we go, what did i break or do I need to run some wire to some pin...
Pop the airbag off again, and notice I hadn't pushed the yellow clips back in. Didn't figure that could be it, but put it back together and started it again. The light went off!!
Too good to be true... Too good to be true...
Test drive time, I notice the cruise indicator on the dash works, good sign. The damn cruise does everything its supposed to flawlessly.. for less than $100... and 30 minutes labor..
Makes no sense toyota doesn't offer this cruise..
Many thanks to Scott for this!
And in this case it's everything its claimed to be.
P.S. If anyone wants the stock steering wheel cover without hole cut, just cover shipping and its yours (note I am in Toronto Area).
Old 05-14-2011, 05:11 PM   #194
burdenj
Drives: 2000 Echo Sedan
Just completed the cruise on my 08' hatchback!
Hi everyone, first substantial post here!
Thanks to this awesome community, my 08' Hatchback now has cruise as well, just put the finishing touches on it this morning.
Please forgive the dirt, it's only just barely spring in St. John's, Newfoundland. Also, that mess that looks vaguely like a circuit is all tidy and covered in heat shrink now
For the switches, I used double throw momentary toggles which are off at the centered position. I know it doesn't look stock like some of the push button switches do, but I just have a thing for toggle switches.
I got them from Digikey if anyone's interested (450-1530-ND).
burdenj is offline   Reply With Quote
Old 05-14-2011, 11:16 PM   #195
Brianr4
Drives: 2008 Yaris 3dr Hatchback
Finally finished installing all of mine and it works perfect!
I think it works better then the factory cc in my Tundra.
Have to give much thanks to CTScott for making the kit...selling the kit...and for being so patient with all my questions!
His brain must be super huge!!!!
Brianr4 is offline   Reply With Quote
Old 05-17-2011, 01:04 AM   #196
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Installed my kit today from Scott. LOVE it!
Thanks again!!!
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 05-17-2011, 07:25 PM   #197
Brianr4
Scott, did the horn plug make it back to you?
Old 05-25-2011, 04:36 PM   #198
bobor
Drives: Toyota Yaris 1.33 5D HB
DIY CC in European Yaris 2009
Hi everybody,
I own my small Yaris and like the car very much. The only minor thing I miss is the CC feature. Since the european models do not have support for CC built in ECU and I do not want to invest too much money in some aftermarket model, so I decided to build my own one.
The idea is very simple. I would like to use a microcontroller to periodically check all necessary input data (current speed, brake & clutch pedal positions, etc.) and then set the digital2analog converter to emulate the accelerator pedal movement by increasing / decreasing the output voltages on both lines to ECU as the speed of the vehicle is under / over set value.
I currently have an open question related to accelerator pedal connection. There are 6 wires for 2 separate Hall probes to detect the pedal position. Of each set, one wire is +5V, second one is GND and the third one is the output, where voltage changes according to accelerator pedal depression level. I would like to cut these two signal lines and put them as input to CC module and connect another two wires (output from CC) as input to ECU. So far so fine.
But my idea is, that during the time CC is switched off, the signal input and output are directly interconnected and when CC is enabled, the output is fed from DAC. I would like to use a relay controlled by microcontroller for this purpose (see fig.). but I am not sure, if it is a good idea. What is your opinion. Is there any better solution for this?
If I use the relay, will there be any problem with temporary loss of signal to ECU during relay switching (the actual switching time is approx. 5 ms)? Or shall I add some small capacitor between output & ground to smooth the glitches. But I have no idea what capacity to use in order not to influence the response time of accelerator pedal too much.
And finally, do you know about any place where can I get at least accelerator pedal connectors (male & female) or the whole accelerator interface harness from ?
I appreciate any ideas. Thanks
bobor is offline   Reply With Quote
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
