C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
Limits of stock 1nzfe found once and for all.
This is my motor with bent rod and cracked block and piston sleeve. This was at 12psi and 197whp dynoed only 2 days before major engine noise on a mustang dyno. Now on to the build of my junk jard motor.
#2 | |
USAF_SrA_E-4
Ouch
Told ya the rods where the first to go lol. Thanks to for getting that Dyno. Be sure to add your info to my durability thread when u get a chance. You pushed it further than i did by 2 psi. At 10psi after awhile I burnt up my valves. How are yours?
Wow. I'll keep the innuendos to myself.
Looking forward to watching your rebuild. Thanks again - this is a vital piece of information for those of us with boost. |
hmmm Gonzo rods :D Sorry to hear that dude, but now we have a better idea of the limitations of the stock hardware :)
Mr. 155 and climbing
It has become obvious that 8psi is the max safe boost level with considerations of even staying at 6 for those folks that are looking for longevity and reliability. Personally in hindsight with my build I wouldn't tell anyone to use an internal wastegate unless they installed a premium turbo. I would also sttrongly recommend performing a compression test before and then again after installation.
I wish that I could reinforce your results, but since I had spiked to over 25psi the couple times my situation isn't a good marker. I will enjoy tearing my motor down especially since my rods shattered.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Did you post the dyno chart from your mustang run?
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
I'm still wondering if there is a difference in the bottom end of the echo/xb compared to the yaris. Blownxa said he went through a few engines just above 150whp in his xa (with a good/safe tune) as well as a couple other xb guys on clubxb.com
Sorry to hear about your engine pimp. How much boost will you be running once it is built?
05' Echo Hatch - Greddy Supercharger - rear disc |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris Turbo Join Date: May 2007
^ They seem identical to me. I've reviewed them side by side. Don't know about part numbers.
Form>Function
thats some high boost for these little guys. Now to the build. Good Luck!
Looking at the EPC, the Echo, xA, xB, and Yaris all share the same part numbers for pistons, rods, and crankshaft. The Prius uses the same rods, but different pistons and crankshaft.
The rods are useless unfortunately. I totally underatand why they are what they are, but it still is a fact.
#14 | |
If we could find out the compression PSI limit of the stock rods, it would be easy enough to run the math to determine the theoretical boost limit.
Crashy would cowering in fear if she could read that post :D
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
I wouldn't tag a certain amount of boost to the limitation of stock rods.... It is power. Most likely the onset of power (torque) is the best measurement of limitation.
Ptuning.com |
True, although it is the instantaneous force of the combustion explosion pushing against the crank before the rotation occurs that does the damage, as that peak force can be in excess of 6000 lbs. That force is the pressure within the cylinder at combustion multiplied by the area of the piston and by the sine of the angle of the rod at TDC (which is about 10 degrees). So, if that force peaks high enough either the bearing or rod will fail.
