Old 05-01-2012, 10:50 AM   #1
llama
Drives: Yaris 2006 1.0 T3
Angry Aerial Help
The nut inside my aerial mount seems to have come loose while changing my aerial..
At the moment there is a screw inside which is fixed in quite tight and since the nut is loose i cannot remove it..
Anyone got any ideas on how to tighten it up? (Preferably without removing the headliner!)
llama is offline   Reply With Quote
Old 05-01-2012, 01:48 PM   #2
Unfortunately you will have to get up under the back of the headliner to tighten it. From the hatch you can pull the left side of the liner down enough to get a hand with a wrench to the antenna mount.
Old 05-01-2012, 02:01 PM   #3
llama
Does this apply for the 3-door too? Yeah its a hatchback by the way :)
Any instructions on how to do this?
Old 05-01-2012, 02:55 PM   #4
It is the same for the 3 and 5 door.
Here's a picture that I snapped for someone who was trying to get at a mouse nest above the headliner:
Work your fingers between the headliner and the weather seal, and the clips will pop out. The left side just has the clips, so you can pop that down, but if you need more access you will have to remove the rear seat shoulder belt mount, which is on the right side. There is a bolt under the plastic cover on the ceiling, that you remove to drop it.
Old 05-01-2012, 06:16 PM   #5
llama
OK thanks ill try that tomorrow and get back to you
Old 05-02-2012, 09:33 AM   #6
llama
There was no way my hand was getting through the tiny gap.. :/
Old 05-02-2012, 10:44 AM   #7
Try dropping the seat belt mount and see if that gives you enough space.
Old 05-02-2012, 11:44 AM   #8
llama
Don't suppose you've got instructions for that do you?
Old 05-02-2012, 11:52 AM   #9
This is from the "Seat Belt" section of the service manual, which can be downloaded from the MicroImage Forum:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 05-04-2012, 12:40 PM   #10
llama
So i managed to fit my hand through, but the nut is tight. It must be something loose on top: Took some photos for you to maybe get a better idea. btw thanks for your help so far :)
Old 05-06-2012, 08:51 PM   #11
The part that the antenna screws to it separate from the piece that the nut screws onto, so the the upper piece must have broken loose. That means either taking the entire thing off and taking it apart to fix it, or replace it.
Old 05-12-2012, 03:22 PM   #12
llama
Ok thanks mate! Will see what i can do
Tags
aerial, loose, mount
Replacing roof aerial mount. pja666 DIY / Maintenance / Service 1 02-24-2012 11:04 AM
Replacing Roof Top Radio Aerial (Antenna) KEVBD In Car Entertainment + Electronics (audio / video / alarm) 0 01-29-2012 02:17 PM
Benefit(s) of bee sting aerial? Pingouin Cosmetic Modifications (Exterior/Interior) 11 09-24-2010 11:00 AM
9/11 newly released aerial pictures tomato Off-topic / Other Cars / Everything else Discussions 10 02-11-2010 11:33 PM
Sedan Aerial Placement? Sp33dY Cosmetic Modifications (Exterior/Interior) 8 08-02-2006 06:50 PM
