Old 05-28-2012, 12:05 PM   #1
Gearheadb6
Drives: 08' white yaris lift
Newbie wheel question... :) sorry if its a repeat.
Ooookay, heres my ordeal:
I have an 08' liftback 3dr- i have a set of bbs lm reps 17x7.5 +40. Im going to put on tanabe df210 the 1.6"/1.8" springs. Anyone running this sort of setup?
Im trying to decide what tires to go with... i was looking at the kuhmo ecsta ast in 205/40/17? How bad do you think ill rub? Im also looking at 195/40/17 from yoko s, would these be better maybe? 5mm spacer on rear?
Thoughts? (I know theres a wheel guide but it doesnt give specific offset info :) )
Ive heard stories of both rubbing and those thay say absolutely no issues. :)
Any heads up is much appreciated! Im a fairly big guy so im worried about rubbing on driver side in specific if driver weight matters. :)
Thanks!
Gearheadb6 is offline   Reply With Quote
Old 05-28-2012, 12:26 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am running AMRs which dropped me 2" in the front and never rubbed on my 205/40/17s. I know those are different springs, but mine are setup with the same progressive response as the stock spring rates. I was as heavy as 275lbs at one point with them on. I only rubbed in the rear with the car fully loaded so that a fly would suffocate when I moved. Not sure how big a guy you are in comparision, but thought that I would offer up that bit of info.
Old 05-28-2012, 12:32 PM   #3
Gearheadb6
Cool! Thank you ^^ thats about the same size i am. I range from 265-275. I was worried about turn at full crank. It looked aweful close when i mached the wheels up :)
Any issues turning wise? Full crank? Also tire pressure sensor? Anyissues?
Thanks fnkngrv!
Old 05-28-2012, 01:31 PM   #4
RcJosh
Drives: hatchback yaris
i have the same springs and similar wheels. i had 205/40 and 205/45 the 45's rub a bunch. the 40's didnt nearly as bad, only big bumps at higher speeds, or if the car is loaded with weight. i never rub turning the wheel though with the 205. so you should be good if you want to go with a bigger tire.
RcJosh is offline   Reply With Quote
Old 05-28-2012, 02:13 PM   #5
Gearheadb6
Right on. Im probably going to go with 205/40 in the front and 215/40 in the rear then. So i dont have to worry about spacers. To flush it all out with the fenders.
Old 05-28-2012, 03:48 PM   #6
vten
I would go with the 205 all around and add the spacer in the back ...that way you can rotate them tires for an even thread .
pics with the rims please ...BBS LM is one of my favourite rims.
Old 05-28-2012, 04:13 PM   #7
Gearheadb6
Hey vten! Will do, ill put pics up this week sometime after i have them mounted. It should look okay. Ill post pics pre- and post- lowering with wheels and springs. :)
Old 05-29-2012, 09:26 AM   #8
33OH
Drives: '08 Yaris
^ What they all said, 205/40/17's all around will be best, and add a 5 or 10mm spacer in the rear. (Be sure to use longer studs if added a 10mm wheel spacer.)
Old 05-29-2012, 06:53 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
A question about wheel weight... CanIHazYarisHatch? Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 11-29-2011 02:42 AM
Supercharger, Nardi wheel, Recaro seats!!! jdmekcivic Items for Sale by private party 165 11-18-2010 12:37 AM
Wheel Well Question gwasabi Cosmetic Modifications (Exterior/Interior) 3 04-15-2009 12:09 PM
Question about wheel Offset monoculusjoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-07-2006 03:03 AM
Wheel and tire question. EddyCocaine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 08-31-2006 11:13 AM
