Old 07-10-2012, 10:09 AM   #37
stuart_f
Drives: Yaris TR 1.33CVT
Also ordered from CTScott and got the parts in UK very quickly and no customs issues (despite USPS tracking saying the package is still in USA!)
I notice my steering wheel assembly is slightly different from Richard_RSP's (but thank you for the pictures that helped a lot in knowing what I was aiming for.
I have the steering wheel audio and also the bluetooth telephone control on my UK Spec 2012, 1.33 Yaris TR Auto (not sure which bit of that means I have the different clips though!)
Also, pin 1 & 2 of the 10-pin connector are already occupied so I put the cruise in the spare 4-pin socket next to it.
Edit- It works!
stuart_f is offline   Reply With Quote
Old 07-20-2012, 03:38 PM   #38
Excellent! I am glad to see that the installation went well.
Old 08-23-2012, 04:15 AM   #39
macoloco
Drives: Yaris
hi...i'm just reading all posts, but i have a question..
are you always talking about 1.33 VVTI, right?
is it possible to have cruise control in a 1.4 D4D 2012 yaris ??
macoloco is offline   Reply With Quote
Old 08-23-2012, 06:20 AM   #40
Correct - According the the wiring diagrams for the European Yaris, only the Yaris with the 1NR-FE (1.33L) support OEM cruise control. Ones with the D4D would need an aftermarket cruise control solution.
Old 08-24-2012, 12:27 PM   #41
macoloco
Drives: Yaris
Thank u very much....
Its a pity....:(
Old 08-24-2012, 07:09 PM   #42
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
hey there scott, got anymore stalks left? i'd love to pick one up from ya...
b20vteg is offline   Reply With Quote
Old 08-24-2012, 08:16 PM   #43
I sure do. I'll PM you the details.
Old 08-24-2012, 08:21 PM   #44
Jamus
Drives: '12 3dr Yaris L
I'm working on installing the 2-button cruise control on my 2012 L automatic. I am having trouble identifying the correct wires to connect to. On the 06-11 D3 plug there is a black wire, and then a blue and brown wire if you have the correct wiring to the computer. Here's a pic I took from under my steering column. If I were to assume, I'd say it's still the brown and blue wires on the plug next to the yellow one. But I'd rather double check with you guys who know.
Link to the type of cruise control mod I'm using.
http://www.yarisworld.com/forums/showthread.php?t=17158
Jamus is offline   Reply With Quote
Old 08-24-2012, 08:31 PM   #45
For the 2012, the CCS wire (formerly blue) is now beige and the ground wire (formerly brown) is still brown. They are the two left most wires on the black connector to the left of the yellow airbag connector.
Old 08-24-2012, 09:02 PM   #46
Jamus
Awesome, thank you very much. I never would have guessed it to be the black plug.
Old 08-25-2012, 10:13 PM   #47
Jamus
Well, I tried to hook this up with no result. I'm partially color blind so maybe I could have the wrong wires. Is there a diagram of the black plugs pins somewhere? Is there a black wire, or a dark brown?
Old 08-25-2012, 10:40 PM   #48
This is the connector drawing (view is looking into the holes where the connector would plug into the clockspring). Pin 1 (beige) is the CCS pin, which goes to the ECM. Pin 2 (Brown) is the ground wire.
Old 08-25-2012, 10:54 PM   #49
Jamus
Thanks for the quick response, and expert electrical knowledge. I used a micro pot instead of resistors. That shouldn't be a problem should it?
Old 08-26-2012, 08:48 AM   #50
The problem with potentiometers is that depending on the construction they can drift. Also, depending on the range of the pot, the under 1K area of the pot can be very small, making it difficult to lock in the correct values.
Old 08-31-2012, 11:06 PM   #51
Jamus
Just wanted to let everyone know I got it working and it's great. I probably ran into every problem that one might run into, but with quick help from CTScott I was put back on the right track. Thanks again Scott, and the forum as a whole.
Old 11-20-2012, 03:21 PM   #52
PierreG
Drives: yaris
Got the cruise stalk in my 2012 3dr., but does anyone know where there is a tutorial to get at the clutch switch?
PierreG is offline   Reply With Quote
Old 11-20-2012, 03:26 PM   #53
The clutch switch on the 2012 is just like the 2nd gen. Look at the top of the clutch pedal and you will see a bolt threaded into the frame, with a stop nut where it meets the frame. Remove that bolt and install the CC clutch switch in its place. The switch should be adjusted to where it is fully pressed in when the clutch pedal is not depressed and, where as soon as you touch the pedal the switch is no longer pressed.
Old 12-28-2012, 04:15 AM   #54
danieldk
Drives: 2012 1.3 Xr CVT
Question
Does anyone know how to access the other 2 clips if you have shift paddles ?
( 2012 1.3 Xr CVT 5Dr )
I found the access hole on the bottom, but none on the sides
some images for clarity : The driver view
The access hole on the bottom:
Left paddle ( gear down):
Right paddle ( gear up ) with the Cruise control cover thing removed
danieldk is offline   Reply With Quote
cruise control. 2012
