12-10-2008, 08:50 PM | #19 |
Bathroom + Laptop = <3
i didnt know that came off too :(
12-11-2008, 11:40 AM | #20 |
Drives: 2009 Yaris liftback Join Date: Nov 2008
12-11-2008, 12:22 PM | #21 |
9 or 10!!! i'll take the lifelong scar thank you very much!!
12-13-2008, 01:32 AM | #22 |
Drives: 2009 Yaris Sedan (Black) Join Date: Nov 2008
hey guys, are the DF210's ok to use on stock shocks? i am a little interested in the 2" drop from the DF's but i like the idea of riding stock suspension on the NF's. hmm cant decide!
12-13-2008, 09:53 AM | #23 |
I've had them on the stock shocks for 10k miles now, you will be more impressed by the DF210's...
12-13-2008, 02:03 PM | #24 |
12-13-2008, 08:52 PM | #25 |
got that right ;)
12-14-2008, 02:00 AM | #26 |
thanks for that info. do you think the shocks will last me the whole lifetime of the car? i plan on using this car as a daily driver too. should i really consider new shocks? if so, which ones would work best iwth the df210s?
12-14-2008, 04:07 AM | #27 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
You don't need to replace the shocks, but if you do, one of the sponsors here is selling the Tokicos (blue, I believe) for a few hundred dollars.
Also, getting to the rear shocks is a b*tch. El Jefe and I had a hard time accessing them. |
12-14-2008, 04:14 AM | #28 |
As you can see with the specs on paper, the S.Techs have a greater drop for the LB (would be even lower for the sedan, as I mentioned yesterday), so I would think the S.Techs should land you more than 2" of a drop.
http://www.tanabe-usa.com/springs/sp...tions.asp?id=1 http://www.tein.com/price/toyota.html HOWEVER, we drove my car to my professors house, and she has a long gravel road. For some reason (probably from so many cars slipping), a mound was form in the middle (the space in between where the tires drive over). With a total of four people in my car and a sub in the trunk, I pretty much shoveled that mound all the way to where her drive way began. On the bright side, not once did I bottom out on the little dips/pot holes in that gravel road. Minor scratches on the exhaust pipe and muffler (my muffler hangs pretty low, as you can see from my pics). |
12-16-2008, 04:54 PM | #29 | ||||
Drives: Yaris 3 Door, 04 WRX, 69 Lotus Join Date: Apr 2007
Not necessary at all
A new sway bar will do nothing in relation to the shocks and springs. Quote:
12-16-2008, 06:06 PM | #30 |
The alignment on mine felt like it didnt need to be done when I first had it lowered but dont let that fool you. You will need to do the alignment. Just make sure you have the right spring in the right place.....front in front and back in back.....I also cut my bump stops. I have been told in the past that if you lower a car-truck you need to cut the bump stop as much as you lowered it. If you lower it an inch then cut an inch off the bumpstop.
I have experienced when you dont cut them you run the chance of hitting them when hitting a big bump. It just allows more travel before it reaches the bumpstop. |
12-17-2008, 05:24 PM | #31 |
Drives: 2008 Yaris HB Join Date: Oct 2008
DF210s can work fine on stock shocks,depending on your driving conditions is how to determine the life of your struts.bumpy potholed roads will lessen the life of them.not slowing for speedbumps will greatly lessen the life........
My rule of thumb is if my car is gonna bottom out in the snow I am calling in sick.....I do no tmake enough to afford repairs. I have 10000 on my DFs now with 17s and they ride great,look great,and my struts are still looking very good. As for installing the springs you need a spring compressor,rent it from Autozone or parts store..really cheap You need an offset 17mm round head wrench for the top nuts on the fronts and a n allen wrench set. Floor jack and stands A friend to help and double check your work. Torque wrench Garage and a couple of cold ones helps too. |
12-17-2008, 06:26 PM | #32 |
Drives: 2006 yaris Join Date: Oct 2008
09-13-2012, 03:51 PM | #33 | |
Drives: 1987 Silverado Join Date: Jan 2010
09-13-2012, 05:01 PM | #34 |
Drives: 2010 black yaris Join Date: Oct 2010
DAAAMN! 4 year later
09-15-2012, 03:29 AM | #35 |
LOL. Well the site recommended this thread to me over on the side, so I blame the site.
Your names derrick https://www.youtube.com/watch?v=3ZcGKHC0Rh8 |
Similar Threads | ||||
Micro Image lowering springs 1.8" drop | markylicious | Middle East | 144 | 10-30-2011 01:18 AM |
TRD Lowering Springs. | Alpha300 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 08-22-2011 11:36 PM |
Swaybar vs. lowering springs | eht13 | General Yaris / Vitz Discussion | 52 | 10-04-2010 07:59 PM |
Is it practical to install stiffer shocks without also installing lowering springs? | St_G | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 01-18-2007 01:23 PM |
