Old 01-12-2013, 01:27 PM   #145
FrankM
Drives: 2008 toyota yaris/2000 mr2
i dont want to try to take them out , to change them ,if they should brake off , it will be a big job.
FrankM is offline   Reply With Quote
Old 01-13-2013, 01:28 PM   #146
FrankM
i take it you drill the holes about a half inch to the side of the bolt head , so the water can drain out ?
Old 01-14-2013, 10:06 PM   #147
Yaristeve
Drives: 3-door hatch
Originally Posted by Hershey View Post
Got the notice earlier .
I just received mine a couple of days ago. It's not a recall notice. It just a warranty extension notice (both miles and time, neither of which I remember off hand) on the part. The notice says that the problem does not warrant a recall because it is not a critical defect because even if the bolt head falls off, the arm is still captured by the brace underneath it (see Don777's pictures, post #54). If the head falls off, the driver should hear the clunking and then he should take the car in for repair.
Old 01-16-2013, 07:23 PM   #148
FrankM
so if it brakes , you dont lose control of the car , just asking ? sounds like a big deal to me .
Old 01-16-2013, 07:47 PM   #149
It won't cause any catastrophic issues if it fails, since it is captive in a pocket. The worst that will happen is that it will thump around in the pocket. You can see the pocket in the picture that I posted in the other thread:
Old 01-16-2013, 08:07 PM   #150
CoryM
Drives: 2009 5-door, 5-speed
As CTScott said, it is unlikely that the control arm will come out. I say unlikely because it is still possible. While the broken part of the bolt will contain the control arm, there is no tension on the threads to hold the bolt in. So if you drive it and do not hear, or notice the noises that (presumably) it is making eventually it is certainly possible that what is left of the bolt will work it's way out. That being said, if the bolt rusted enough to break, chances are the threads are rusted as well which will help hold it in. I'm willing to bet that eventually someone, somewhere, will have the back of a control arm bolt fall completely out. I'm always amazed at what some people do not notice on their cars. Some people drive with wheel bearings so noisy you have to yell to be heard over them, and they have no idea there is something wrong.
In regards to where to cut/drill to drain the bushing, I haven't had a chance to get my car on the rack yet (and I need to re-align my car any time those are out. Rebuild/Racecar :þ ). In the above picture, in the middle of the black rubber part that CTScott drew a line through is a metal cylinder that the bolt goes through. That cylinder (sleeve) is what needs to be drained. So either a small nick in the edge of it, or a cut in the subframe below to help drain. Toyota is trying to seal it, which may or may not be feasible.
Cheers.
Old 01-17-2013, 10:53 PM   #151
LugNut
Drives: 2007 2DR Liftback
This repair covered for non-original owners?
LugNut is offline   Reply With Quote
Old 01-20-2013, 05:40 PM   #152
vadr45
vadr45
vadr45's Avatar
Drives: 2009 Base 3-door
Yes. I am the second owner and I received the warranty extension last week.
vadr45
Alexandria, VA
2009 Black Base 3-Door Yaris
1950 Austin A70 Hampshire
vadr45 is offline   Reply With Quote
Old 01-24-2013, 06:34 PM   #153
Crazy Butcher
Drives: Yaris 2008
I get some rattling/creaking noise at about 1500k rpms to about 2k rpms, especially on the front driver side, could this be the cause of the rattling/creaking? as soon as i get over 2k-2.5k rmps it stops. it happens mostly when its cold outside. It also happens oftenly when i take off at lights and stops since i go back down to the 1.5k 2k rpms range.
Crazy Butcher is offline   Reply With Quote
Old 01-24-2013, 06:40 PM   #154
Possibly. Stick your hand down there and see if you feel the head of the bolt or if it is gone.
Old 01-24-2013, 06:51 PM   #155
Crazy Butcher
Drives: Yaris 2008
Thanks alot Scott ill check it out tomorrow, its been doing it for more or less a week now, should've posted the first day it did it
Old 01-24-2013, 07:41 PM   #156
clarenceie
Drives: Yaris Sedan
I live in dry California. Do you think I should change this out? I went to the Toyota owners site and didn't see any recall regarding this.
Just for reference, what is the part number and how much should it cost approx?
clarenceie is offline   Reply With Quote
Old 01-24-2013, 09:20 PM   #157
The bolts are 90119-14126 (2 are required and they cost less than $4 each).
I suspect that everyone will eventually get the warranty extension notice. I think it is worth at least keeping an eye on them. If they don't look too rusty, pull them out and check the entire bolt. If the head looks rusty at all, then it is probably best to avoid being the one to snap it off.
Old 02-11-2013, 08:21 PM   #158
Cutie Pie #2
Drives: 2014 Honda CR-V LX
Just got my letter today, and yes I do hear a creaking noise in the front that it says, so I will be making a trip to the dealership soon.
Cutie Pie #2 is offline   Reply With Quote
Old 02-11-2013, 09:23 PM   #159
Haven't got a letter in the mail yet, but I might as well go to the dealership and buy those bolts. I don't recall seeing any rust on my car when I installed/uninstalled the Megan tie bars.
Old 02-12-2013, 05:14 PM   #160
Well now, my local dealership is charging me 15 bucks for 2 bolts.
Old 02-12-2013, 07:08 PM   #161
nookandcrannycar
That's the Bay Area for ya.
Old 02-12-2013, 08:31 PM   #162
Parts guy laughed at me when I said I thought it was 4 bucks each
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
