Old 01-12-2013, 05:20 AM   #1
unclenefeesa
Da Uncle
Drives: 2008 Toyota Yaris Sedan
Increased ground clearance between 2008 and 2010 Sedan
Hi all,
I know I have not posted much here, but I wish I had more to share with the rest of the forum. You guys are great and always enjoy reading about all the mods even though I can't get any of them where I live.
Anyway, does anyone know of an increase in ground clearance from 2008 to 2010 and later models of the stock sedan?
I have a 2008 Sedan (185/60/R15) myself and 2 other 2010 Sedan (175/60/R14) one for a member in the family and the other for a neighbor. I always found that the tire clearance on the 2010 is more than what I have. I though it is due to the smaller tire, which led to the difference in the ground clearance.
However, I have had the chance to compare same model sedan (2008) to mine but with the smaller tire size and there is minimal difference.
I also got the chance to compare different tire size on the 2010 models also where I also found minimal difference.
The bottom line I found about 1/2 an inch (0.5 inch) in ground clearance between 2008 and 2010 models.
Can anyone confirm?
Is it possible that Toyota started putting higher spring/shock absorbers starting with 2010 models?
I always thought the only difference is the front grill !
unclenefeesa is offline   Reply With Quote
Old 01-15-2013, 06:23 AM   #2
unclenefeesa
Da Uncle
Unhappy
No one else noticed
or no one likes me
Old 01-15-2013, 10:20 AM   #3
ciscobear
Drives: Toyota Belta
LOL, might indeed be different springs.
ciscobear is offline   Reply With Quote
Old 01-15-2013, 10:45 AM   #4
Springs get tired as they age. You are probably just noticing spring sag.
Old 01-16-2013, 09:55 AM   #5
unclenefeesa
Da Uncle
The other cards have more mileage than I do. I have around 32000 KM (~20K miles). I've been checking other cars and it seems that all older models (2008) have the same height and are all lower than newer 2010 models.
Either way, I am only concerned that if in the future I need or want to change something in the suspension there won't be like a million variations of the same part.
Thanks guys.
Old 01-16-2013, 01:21 PM   #6
Jason@SportsCar
Start looking at part numbers... There is a reference to a "Rough Road Package" in the suspension section of the factory shop manual. It could be you are seeing some cars with it and some without in your market.
Old 01-17-2013, 05:49 AM   #7
unclenefeesa
Da Uncle
That's right
I didn't see that part before. It might just explain the difference.
The Dealer would have started getting them with the rough road package starting from 2010.
Good catch Jason.
Tags
2008, 2010, ground clearance, sedan
2008 JDM Vitz RS rear bumper on 2010 USDM LB? DeathBeard Cosmetic Modifications (Exterior/Interior) 14 09-30-2012 11:49 AM
