Old 02-19-2013, 03:06 PM   #1
Yarflana
Drives: 2008 Base Model
Best "lifters" for hatchback...want improvement
You know the "lifters" on a hatchback that keep the hatch open while doin' stuff back there?
Mine are losing their ability to hold the hatch open and I was curious where to get some good ones that will hold it well, open faster (more lifting power) and last longer.
Thoughts?
Thanks,
Pat
Yarflana is offline   Reply With Quote
Old 02-19-2013, 04:38 PM   #2
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
I'm not sure if the 08 model is the same as the 07 HB, but I purchased these gas struts from ebay - work like a charm!
http://www.ebay.com/itm/90LB-Columbi...item5652438a30
MyzticZ3r0 is offline   Reply With Quote
Old 02-19-2013, 05:09 PM   #3
MadMax
MadMax's Avatar
Are you in San Antonio? I ask because we saw a hatch that looked just like yours on Bandera Road about an hour or so ago, I think it was at the Sonic just past Grissom...
My teenage son and I were in my Jeep but we always play "Slug Yaris" (like "Slug Bug," but for Yaris hatchbacks), so I tend to remember seeing them...
Cheers! M2
Old 02-19-2013, 05:57 PM   #4
Somewhere on here is a large-ish thread on replacement hatch struts. I believe CTScott has recommended a good replacement that is not too stiff. A common complaint with some replacements tried is that they are just too stiff.
Gotta be carefull as you don't want this to happen (even if it was done with OEM struts).
http://www.yarisworld.com/forums/sho...60&postcount=3
Old 02-19-2013, 06:19 PM   #5
The biggest thing to look for is ones that are dampened. The cheap ebay ones that I initially experimented with were not, and they really bounced the hatch at the top of travel. As for lift strength, 90 lbs, like the ones that Myztic posted the link to are good. If you added sound deadening material to the hatch, then you would want to go up to 100 lb lift ones.
Old 02-20-2013, 03:06 PM   #6
Yarflana
Sorry, but I am in Cypress, just outside Houston, TX. I have been to SA a few times, but not recently. There are a lot of gray Yaris's around.
Take care,
Pat
Cheers! M2
Old 02-20-2013, 03:06 PM   #7
Yarflana
Ok makes sense...will do.
Old 02-24-2013, 11:44 AM   #8
RedRide
RedRide's Avatar
Check out this site....."Lift Supports Depot.com"
http://www.autopartsbylou.com/lift-s...pe=mmy&x=5&y=7
I do know that people who have purchased lifts for other cars say that they are top quality so, I have to assume the Yaris supports are great also.
Yaris supports are $15.75 each. They also have installation tips/FAQs
Old 02-24-2013, 12:52 PM   #9
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
every time i see this title i think it is referring to hydraulic or roller lifters in the engine.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
What, if any, performance improvement would you get from this product? *MAD DOG* Performance Modifications 9 10-08-2009 07:14 PM
Halogenas & Ground Improvement abdiel hiram Central and South America 32 06-20-2007 08:06 AM
realalistic sound improvement uncleyaris In Car Entertainment + Electronics (audio / video / alarm) 7 02-15-2007 10:59 PM
