Old 02-21-2013, 09:21 PM   #199
UberSilver
UberSilver's Avatar
Update, as I said before, my stock bolts were fine. But all of the creaking is gone.
So I guess the bolts had become lose over time. I also retorqued all of the bolts, so that may have done it as well.
Old 02-22-2013, 07:30 PM   #200
NEexpat
Drives: 2009, auto, 4dr LB
*Got my notice yesterday about extending the warranty on these bolts.
NEexpat is offline   Reply With Quote
Old 02-22-2013, 08:16 PM   #201
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
just got my letter the other day it reads 7 years from the vehicles date of first use or 100,000 miles whichever occurs first . mine is setting at 99,000 and need my main window switch taken care of also on a recall by toyota
pennyracer is offline   Reply With Quote
Old 03-01-2013, 03:05 PM   #202
Hard Time
Retard
Drives: 08 Yaris 3dr hb
Warranty letter for broken bolt......
Got a letter from Toyota today saying warrenty is extended for a "front suspension lower arm number 2 bolt" that may be corroded and break. Warrenty covers years "late 2006" to "early 2011". Any comments on this?
If ignorance is bliss, why am I not happy?
Hard Time is offline   Reply With Quote
Old 03-01-2013, 03:16 PM   #203
Hard Time
Retard
I just got it today. Funny coincidence. Two weeks ago I was turning onto an entrance ramp to a highway and heard something snap. As I got up to the speed limit I start noticing a sound that I hadn't heard before. Since I had a lot to do that day I put the problem out of my mind and forgot about it. So today I get the letter. Good timing, right? The sound I was hearing was not a knocking or rattling sound. It was more of a consistent sound. My car is a 2008 hatchback with about 48000 miles on it.
Old 03-01-2013, 06:01 PM   #204
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
Got a notice too, next oil change in about 800 mi so I'll have the dealer take a look. If they report no problems, I'm going ask for that in writing for future issues. Yet here in New Mexico other than some spot precipitation last couple of years. We are in a drought.
Killchain is offline   Reply With Quote
Old 03-01-2013, 07:15 PM   #205
jayeh
Drives: '08 Yaris LB
You can have as much of the 1 foot of snow that fell yesterday as you want. You just have to come pick it up.
Anyone in Canada get one of these?
jayeh is offline   Reply With Quote
Old 03-01-2013, 07:43 PM   #206
nookandcrannycar
Several times, both here in Texas and in Florida, I've heard natives debating cold climate natives who are complaining about the heat. Each time the discussion has ended with the FL or TX native saying 'You don't have to shovel humidity'. Each time the cold weather native has had no answer, because there isn't one .
Old 03-01-2013, 08:07 PM   #207
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i'll take heat every time. I worked outdoors in florida. 110 degrees in the direct sunlight. I'll take that every time over snow. And I sunburn. My nick name when i played football was 'the red lobster." that was the color of my skin after the first day of doubles, and it didn't change until well after the season ended.
Colin Chapman disciple
Old 03-06-2013, 06:24 AM   #208
DevilGirl
Drives: 09 3dr LB MT
Ironically enough, I received my notice 2 days ago. Unfortunately for me, they sent it to me about 1000 miles too late. I had already turned over 100k on 2/22/13.
Old 03-06-2013, 09:30 AM   #209
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
cost me $12.92 cnd for a pair of these bolts..
Old 03-07-2013, 10:31 PM   #210
Essnowyt
Drives: 2008 Yaris Sedan
This is the aftermath. I found the bolt head on the floor in my garage. This was in August. The repair was in July. I had to pay for the repair, before the warranty enhancement. I just finished writing Toyota for reimbursement.
Ill post again once I have a response from Toyota.
Snowy.
Essnowyt is offline   Reply With Quote
Old 03-12-2013, 11:10 AM   #211
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
That's because they know when to stop blowing hot air!
Amdkt7 is offline   Reply With Quote
Old 03-12-2013, 06:31 PM   #212
nookandcrannycar
LOL
Old 03-16-2013, 12:10 PM   #213
Killchain
Killchain's Avatar
Just got blessed by Toyota, I got a oil change completed. Yet I requested a inspection of the Lower Arm # 2 bolt. No corrosion, bolt was intact. They put that in writing on service receipt . Like I said earlier here in New Mexico we are high and dry for moisture. Yet I will always ask for the inspection of that bolt.
Old 03-25-2013, 09:47 PM   #214
matthvm
Drives: Yaris
I had my 2008 Yaris in for an oil change and door switch recall and they discovered the bolts on mine had broke . 104,000kms on the odometer - the dealer told me it was going to be paid by Toyota
matthvm is offline   Reply With Quote
Old 03-25-2013, 10:38 PM   #215
Hershey
We've had door switches replaced under warranty . The other rear door is sporadic with the dome light lighting . Had it in , but it worked while in the shop . Never fails . No recall here in the States . Not that I'm aware of .
Old 03-25-2013, 10:42 PM   #216
The power window switches are the recall item.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
