04-05-2012, 12:55 PM | #1 |
Vitz_RS
Drives: Toyota Vitz RS NCP91 Join Date: May 2009
Error Code: PO453
Hello,
Can someone help how to resolve Error Code: P0453, check engine light in on..please help. P0453: Evaporative Emission Control System Pressure Sensor High Input |
04-05-2012, 01:51 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
That indicates an issue within the evaporative canister back by the gas tank. P0453 could be caused by any of the following:
Canister pump module • Connector/wire harness (Canister pump module - ECM) • EVAP system hose (pipe from air inlet port to canister pump module, canister filter, fuel tank vent hose) • ECM Look at page 207 of the Engine Control section of the service manual and work your way down from there for instructions on how to determine what the actual problem is: http://www.microimageonline.com/foru...32-YARIS-FILES
04-05-2012, 03:25 PM | #3 |
Vitz_RS
Hi ..
The Fuel Pump and filter were replaced to new still the error is here, where is the canister situated can it be repair, the ECU is a new one |
04-05-2012, 03:31 PM | #4 |
Vitz_RS
do you know where the CANISTER PUMP MODULE is? please
04-05-2012, 04:07 PM | #5 |
04-07-2012, 08:09 AM | #6 |
Vitz_RS
i check mine today, there is no box like in the picture, there only the small box
04-07-2012, 08:10 AM | #7 |
Vitz_RS
Please find Pics
04-05-2013, 03:22 PM | #8 |
Vitz_RS
does anybody know how to solve? thx
04-05-2013, 03:56 PM | #9 |
I now see why yours lacks the evaporative canister.
Here is the system on yours: Japan - Evap.jpg Here is what ours looks like: US - Evap.jpg I would suggest disconnecting the charcoal filter (the little box on the rear left of your picture above) and verifying that it is not fuel or water saturated.
04-06-2013, 05:37 AM | #10 |
Vitz_RS
Hello Scott, do you where around it will be, i am not able to locate it from the diagram
04-06-2013, 06:28 AM | #11 |
Vitz_RS
I am able to remove the little box, how to open it, please
04-06-2013, 07:10 AM | #12 |
Vitz_RS
Scott i need this box to be replace, can you get me one, email naseemkhoodaruth@gmail.com
04-06-2013, 11:06 AM | #13 |
Modded Moderator
Moved this thread to the maintenance section.
04-08-2013, 11:20 PM | #14 |
Drives: 08 Yaris Sedan Join Date: Oct 2008
Its most likely a bad fuel tank pressure sensor. I believe its a 2 wire sensor thats located somewhere on top of the gas tank thats pressed in. Never changed one on a yaris but typically thats the most common for that code. That or a stuck closed canister purge valve.
04-08-2013, 11:32 PM | #15 | |
