Old 11-26-2012, 11:57 AM   #1
dholton
Drives: Toyota Yaris
Smile Cruise control on 2009 Toyota Yaris
I'm thinking about installing cruise control on my 2009 Toyota Yaris. Do you recommend doing this? How complicated is it to install? This feature was not on the car when I bought it.
Thanks so much.
dholton
dholton is offline   Reply With Quote
Old 11-26-2012, 12:17 PM   #2
Thanks so much.
dholton
Is your 09 a sedan or hatchback? And, if it is a sedan, does it have the power package (power windows and locks)? Also, manual or automatic transmission?
Installing cruise control is very easy on a Yaris, and particularly easy on an 09 or newer hatchback or 09 or newer sedan with power. This is because these Yaris have all of the wiring in place, so you only have to install the cruise control stalk (and the CC clutch switch if it is a manual transmission Yaris).
My DIY below shows the soup to nuts of the installation. Also, I sell all of the parts required for a fraction of dealer cost.
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 05-09-2013, 08:15 PM   #3
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
CT, I have a 2008 sedan with power windows and locks. I saw this on one of your earlier posts, "Currently, it is believed that this will also work for 07-08 Yaris, but a wire will have to be connected to connector A21 of the ECM or Connector AD4 (which is located above the top of the fuse panel, just under the dash)." Does this mean EITHER connector A21 or AD4 or is it case by case? I checked next to the steering wheel and I have the cruise control wires on connector D3.
yours_falsely is offline   Reply With Quote
Old 05-09-2013, 08:16 PM   #4
Take a look at this thread for all of the details for your 2008:
Old 05-10-2013, 10:07 PM   #5
yours_falsely
I've read all the material and everywhere I've read said that the 2008s shouldn't have the wires in D3. Mine does. I tried the install today; plugged into the ecm and spliced into the cc wires under the steering column and I can't seem to get it to work. I'm not sure as to what to do. I'm checking my resistors right now
Old 05-10-2013, 10:11 PM   #6
I haven't heard of a 2008 that was pre-wired. Were the wires in D3 blue and brown? And, you had the D3 wires, but not the ECM wire?
Old 05-10-2013, 10:15 PM   #7
yours_falsely
Light blue and brown. No ecm wire.
Old 05-10-2013, 10:25 PM   #8
OK. That is like a 2009+ Sedan without the power package. So, the blue connects to the ECM wire (or if you are doing the switch method, it just connects to one end of the switch chain). The brown (or the other side of the switch chain) gets connected to chassis ground (or if you test it with a multimeter, you may find that it is already grounded).
Is your car MT or AT?
Old 05-10-2013, 10:30 PM   #9
yours_falsely
Auto. So, If I'm using the switch I don't need to connect to the ECM? Do I ground the other side of the switch or connect it to the brown? I apologize for all the questions, I've been trying to get this to work for a while now so I just want to make sure.
Old 05-10-2013, 10:34 PM   #10
If you are doing switches you don't connect to either of the D3 pins, but you do connect one side to the ECM (since he is doing the CC work) and the other side to ground:
Definitely check your resistors as well. A common mistake is to have values that are 1000 times what they should be.
Old 05-10-2013, 10:38 PM   #11
yours_falsely
One last question (for now). If I'm using the two switch config, can I use a 680ohm resistor? In you post you said it could be replaced with a 567-693 one.
Old 05-10-2013, 10:42 PM   #12
A 680 should be fine, provided that it really is 680. With a 5%+/- tolerance it could actually be as high as 714 Ohms, if it is on the high side of the tolerance.
Old 05-10-2013, 10:44 PM   #13
yours_falsely
Righteous. Thanks again CTScott, your expertise is always very much appreciated.
Old 05-11-2013, 12:36 AM   #14
yours_falsely
Got it going. Very cool
Old 02-21-2023, 04:30 AM   #15
PeterHamedani
Drives: Yaris 2009 Hatch Manual
Thanks so much.
dholton
Hi. Sorry it might be quite late after a decade....But I have a Yaris Hatch 2009 Manual with automatic windows...Is there still anyone here who can help me with the installation of the cruise control? I am in Australia and need to buy the tools for it.
Best
PeterHamedani is offline   Reply With Quote
Old 02-24-2023, 09:36 AM   #16
Neinris
Best
https://www.yarisworld.com/forums/sh...cruise+control
Watch this video:
https://www.youtube.com/watch?v=nxRHFkUwg60
Yes it's the sedan, but it'll work on the HB, cause I installed one in mine.
Old 04-04-2023, 03:27 AM   #17
KermitAUS
Drives: Yaris 2009
I am in the same boat, in Australia.
Can we chat?
KermitAUS is offline   Reply With Quote
GT5 Gran Turismo 5 Bluevitz-rs Off-topic / Other Cars / Everything else Discussions 144 03-04-2011 09:13 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
