05-17-2013, 12:53 AM | #1 |
Drives: soarer Join Date: Feb 2011
Noob turbo (zage) questions
Decided to start another thread as i have lots of really noob questions
Below is what I plan using for my oil return: 10AN fittings. Question: Do i need any sort of paste or compound to assemble these things? There are not any sort of rubber spacers inside. It looks as if I just need to assemble them tight and aluminum against aluminum (convex vs concave surface) should provide a tight seal. Opinions? Thanks |
05-17-2013, 01:47 AM | #2 |
やりすぎだ~
Do not use tape or paste on AN fittings. The taper seals it.
05-17-2013, 01:50 AM | #3 |
thanks
05-20-2013, 10:49 PM | #4 |
What engine oil are you (turbo heads) using?
Can I keep using Pennzoil Platinum 5w30 (that I like a lot)? |
05-21-2013, 07:54 AM | #5 |
I'm pretty sure oils will indicate in writing on the back weather they're safe for turbos or not. Full synthetics usually work best.
05-21-2013, 10:47 AM | #6 |
Drives: 07 Yaris Turbo Join Date: May 2007
5w30 synth is good -- I don't run anything exotic. I change it a lot more often.
05-21-2013, 12:21 PM | #7 |
^ Thanks
05-21-2013, 10:39 PM | #8 |
Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
I'd use permatex black or equivalent where the fitting connects to the inside/outside of the block. You won't be threading it into the block, as it's too thin to really grab any of the threads.
05-21-2013, 11:51 PM | #9 |
^ Thanks
This is p.black I belive. Will buy some for my install http://www.amazon.com/Permatex-82180.../dp/B0002UEN1U The scariest part right now seems to be drilling )) One does not come to drill a 18 mm hole in this engine every day )) |
05-22-2013, 12:29 AM | #10 |
18mm? that sounds a lot larger than necessary.
05-22-2013, 01:23 AM | #11 |
10AN - 18 mm oustide diameter - just measured it http://www.ebay.com/itm/181134096470...84.m1497.l2649 plaan to use something like this stepped bt |
Similar Threads | ||||
Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
FS: Zage Turbo kit, AEM FIC with Pnp Harness | djgab101 | Items for Sale by private party | 32 | 04-11-2013 10:42 AM |
Zage turbo kit | Mister Z | Forced Induction Forum | 17 | 11-26-2010 03:32 AM |
noob here.. need help on questions about turbo and engine life | 10Kyaris | Forced Induction Forum | 43 | 10-06-2010 09:26 AM |
zage turbo kit..! just need some help | joseyaris | Forced Induction Forum | 12 | 10-29-2009 08:35 PM |
