#19 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Thanks, yea the motor did have a good life. Im not too upset because I feel I got a lot out of it. Even though It has been a week, I do miss driving that car.
Ptuning.com |
#20 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
When are you going to tear into it to see what needs to be fixed?
#21 |
I have time finally, and plan to pull the head tomorrow here at home. Ill take a few pics
Ptuning.com |
#22 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
finally i was starting to think you forgot about us. :P
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#23 |
Mr. 155 and climbing
very curious!
#24 |
my focus was in another place for a while, so my xA was on the backburner. I attended a world cup downhill race a couple weeks ago, and had a good spill during a practice run. Im back to normal now after a concussion, which took a while to shake. Unrelated, but here is the video... I was on the outside of another rider and ran out of road, sherrif found me unconsciousness face down in the water. http://youtu.be/Udk_TqRY4rc
Ptuning.com |
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris Turbo Join Date: May 2007
![]() wow.
#26 |
Bent cylinder 3 intake valve. Cly 4 damage is from a detonated spark plug ( 6 months ago or so). I reported about that on here in another thread ( Ill bump it). The valve definately indented an impression on the piston, but It isnt structural damage. The damage in cylinder 4 from the spark plug ceramic floating around is rather bad. The wall is really scored, the piston top is knicked up and blasted.
My plan for now is to put another head on, with stiffer valve springs, and higher lift cams. I want to then find the structural limit of this motor (40psi?) . Instead of starting over with a fresh bottom end now and risk damaging it (because im greedy), Id rather not waste a whole new build on experimentation.
Ptuning.com |
#27 |
Yes!
#28 |
face down in the water! DAAAAMN
glad you made it out (and 3rd place! wow) |
#29 |
replacement head, ready to go on this weekend. Supertech valve springs installed, head decked and cleaned.
Ptuning.com |
#30 |
sooo shiny
#31 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
#32 |
xA is together and running !
Ptuning.com |
#33 |
pictures/video or it didn't happen. :P
#34 |
I drove it around last night, the valve springs alone have made a noticable improvement in power above 6600rpm. With the oem springs the car was probably experiencing valve float robbing the power. The dyno will tell the story. I was going to do more work (cams, maybe valves), but I need my car squared away and dialed in for an event coming up. However, expect a good gain because this thing is going to be tuned for some crazy boost levels .
Ptuning.com |
#35 | |
#36 |
I bet once next summer roles around you and I would have a bunch of fun!
Finally!!! | SkittlePig | Australia | 11 | 07-05-2010 07:49 PM |
FINALLY!! | nickhjort | DIY / Maintenance / Service | 18 | 01-16-2009 11:09 PM |
Yay finally got my YRX (photos) | Spikeles | Australia | 15 | 11-12-2008 03:16 AM |
I'm FINALLY getting my Yaris! | sherryberry | New YARIS Purchase Forum | 22 | 07-09-2007 12:08 PM |
Finally! | KittenRD | New YARIS Purchase Forum | 6 | 01-01-2007 09:16 PM |
