Old 01-05-2009, 03:04 PM   #1
DIY (sorta) - RunStop Rear disc brake conversion
Had this written up and lost in the hack, going from memory so might miss a couple steps
Not really a DIY, but a documentation of the steps to install the RunStop rear disc brake conversion kit. It's really simple!
1) Obviously, get the car up on stands and remove the wheels. I don't have much pics at this point, but you then need to remove the 4 bolts that hold the wheel hub to the suspension, and remove the hub, as well as the drum brake plate. You also need to clamp shut the brake fluid line, as it will need to be disconnected (you can see this in the 3 photos below), and remove the handbrake line, as well as the plug for the wheel speed sensor (only if you have ABS, I believe)
2) With all that removed, your car should look like this:
3) Now we reassemble, with the new brake bracket plate (note the small drum brake shoes on the inside, those are still used for the handbrake), followed by the wheel hub:
This, by the way, is the stock drum brake plate:
4) Now the fun part, the new discs and calipers!
First slip the disc over the lugs. To hold it in place for the next few steps, you can screw on just 2 of the lug nuts (if they don't screw in all the way you should find some kind of spacer, or just use a regular nut).
5) The caliper is then positioned and secured from the back side with the two black bolts provided (not shown, but you can see the holes through which they go in the next picture)
6) The pads are inserted, then held in place with the long black bolts, inserted from the back. Then, use the metal spring clips (not pictured) to hold the pads in place.
7) Next we need to do the lines. The handbrake line, if I remember correctly, just screws back on at the back of the brake holding plate. For the brake calipers, the kit includes a new bendable metal line, which you must shape to fit, and connect back to the main brake line on the car chassis:
And that's preeetty much all there is to it... just repeat on the other side. Don't forget to take off the clamp, and bleed the brakes after installation.
The results:
Additional notes:
Get your own kit from Micro Image!
The rotors are 285mm if I recall correctly, so this requires a 15" wheel at the minimum. They do come with slotted discs (mine were prototypes so not slotted), and unpainted calipers (so you can paint them any color you want, if you want)
Old 01-05-2009, 03:58 PM   #2
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
You've got me wanting this rear disc conversion all over again.
Do Runstop sell this conversion kit without the caliper?
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 01-05-2009, 07:23 PM   #3
If you get it from me, it's only offered as a complete kit. I do stock spare rotors and pads, by the way.
Old 03-16-2012, 03:50 AM   #4
booyah
Drives: 2012 Yaris RS Thai Spec
eTiMaGo i'm in BKK and will be getting a Yaris 2012 RS next moth,
would like to talk about some of your mods and what i can do to my future ride, would def be interested in rear disk conversion and proper projector headlights.
Any help would be appreciated.
booyah is offline   Reply With Quote
Old 03-31-2012, 11:43 AM   #5
"G"
Drives: 2007 Yaris Hatch
Aren't these conversion parts available from toyota?
"G" is offline   Reply With Quote
Old 03-31-2012, 11:54 AM   #6
sure, drop me an email, etimago-at-gmail.com! But as far as I know, the new RS spec already has rear disc brakes?
Yes and no, you could certainly find a way to get the OEM parts from the Yaris that are equipped with rear discs, but if I understand, this requires a different version of the whole rear suspension beam!
Old 05-14-2012, 10:13 PM   #7
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
i want this kit, but where to buy?
manborn is offline   Reply With Quote
Old 05-14-2012, 11:41 PM   #8
vten
microimageonline.com ask for garm or jeff
Old 05-15-2012, 03:53 AM   #9
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
It is no more available....:(( i wanted it too
Interior:ALL red, black roof
Old 06-06-2012, 05:23 PM   #10
Jerkratt
Jerkratt's Avatar
this kit might not be available but there is also the KIDO kit if i remember correctly also on microimageonline.com
"It hurts more when its wet"
Old 03-22-2013, 03:15 PM   #11
Movetoyou
Movetoyou's Avatar
Drives: 2010 Toyota Yaris Hatchback
I found this on Wilwood's site for the combination caliper and parking brake. I was just wondering if it could some how be retrofitted to the Yaris rear brakes? http://www.wilwood.com/Search/PartNo...f=Rear%20brake
Movetoyou is offline   Reply With Quote
Old 09-20-2013, 01:25 AM   #12
kingekos
Drives: White 5spd Hatchback
I am looking to buy this rear disc conversion and went to the website to order and it was not available can some one please help me???
kingekos is offline   Reply With Quote
Old 09-20-2013, 12:21 PM   #13
I have a couple on the way in an incoming ocean freight shipment. I think two kits.
Old 09-21-2013, 07:55 PM   #14
manborn
are u still 34/39?
manborn's Avatar
price? just curious
Old 09-24-2013, 08:26 PM   #15
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Garm PM me on that rear conversion!
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-18-2018, 02:48 AM   #16
Cosmo88
Drives: BMW 5
so you can do this with only 2 switches? on/off and set?
รูเล็ต
Cosmo88 is offline   Reply With Quote
Old 07-01-2019, 11:57 PM   #17
gnaris
any kits available?
gnaris is offline   Reply With Quote
Old 07-02-2019, 08:24 AM   #18
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by gnaris View Post
any kits available?
Considering that the post by MicroImage is almost 6 years old and that they're no longer in business, I'm gonna go with no. The good news is that you can do this with OEM Yaris SE parts (rear axle, hubs, etc.), which may be available from a scrap yard.
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
