Old 10-15-2013, 12:45 PM   #19
bairjo
I think CTScott already gave a suggestion
bairjo is offline   Reply With Quote
Old 10-15-2013, 01:29 PM   #20
Originally Posted by caper26 View Post
I had the codes read with OBD II. It was misfire on 2 & 4, and random misfire codes. Wondering what I should do now.
Clear the codes. Swap the coils from 2 & 4 with 1 & 3. If the coils are bad, then the next cel should indicate misfire on 1 & 3. If it is still 2 & 4, then spark plugs are next to look at.
Old 10-15-2013, 02:34 PM   #21
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
We pay mechanics to find the problem and fix it. Just because they want to use a computer at MY expense, doesn't sit right with me.
Often poorly done work (e.g. not checking a battery that was in fact dead and blaming it on the ECM) let me come to the decision to fix my cars on my own, including maintenance.
In the end, it saves me a lot.
I had changed the air filters in less than half a minute, changing oil and its filter were done in less than an hour.
~20€ or so for the 3 filters, 50 for a canister of oil that's still got about 2l in it, that's totally okay for me to spend that every second or third year.
Paying the workshop 100€ in addition (some rumors said even 200€) isn't at all.
I lose the rust warranty, but if it rusts too bad in about 10 years or so, the saved money will be by far enough to fix it
dj92 is offline   Reply With Quote
Old 10-16-2013, 12:27 PM   #22
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
Thank you. This is really annoying with under 40K km's. I cleared the code last week, and will see if it returns.
I read somewhere there has to be a certain number of misfires before the CEL lights up?
caper26 is offline   Reply With Quote
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
yaris engine check light keeps coming on mattuk10 DIY / Maintenance / Service 6 07-24-2010 11:44 AM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
