Old 11-23-2013, 07:50 PM   #1
ivanstepul
Drives: 08 hatchback
Race gas mixture!
mixing 110 racing gas with vpower . It is harmful to the engine and if not what is the right ratio? I have mixed 3 gallons 93vpower gas with 1/9 gallon race gas.
ivanstepul is offline   Reply With Quote
Old 11-29-2013, 12:16 AM   #2
juicyjosh
juicyjosh's Avatar
Drives: 2012 Yaris SE MT
Don't believe the rice.
It's not harmful to the engine, and the best ratio is 0:1.
If your engine is stock, the ecu has been mapped by Toyota to run on regular American gas. Simply putting 110 octane into a stock Yaris engine doesn't turn it into a racing engine. Instead, compared to regular gasoline, the stock Yaris engine with "110 octane" in the tank will produce less power due to the fewer number of high energy molecules per volume injected into the engine, per the chemical composition of the fuel designated as "110 octane." Less power per volume of fuel means that more "110 octane" fuel is required by the engine to produce the same power and torque produced by a comparatively lesser volume of 87 gas, so fuel mileage is also reduced.
High(er) octane fuel is used to help prevent preignition and detonation in forced induction systems or in high compression N/A applications. A stock Yaris engine is neither of these.
juicyjosh is offline   Reply With Quote
Old 11-29-2013, 10:12 AM   #3
^ what he said
Old 11-30-2013, 09:55 PM   #4
ivanstepul
Ok thanks. Idk it feel like it runs better? I have intake header exhaust
Old 11-30-2013, 10:48 PM   #5
09cptn
Drives: 2010 Yaris Sedan
Placebo effect maybe?
The Yaris: 2010 Yaris base model. 50% tint up front and 35% in the rear, Konig Lace wheels with homemade Toyota center caps on Yoko S.drives, Curt hitch.
Offroad: 2004 Jeep Wrangler lifted on 33's
09cptn is offline   Reply With Quote
Old 12-01-2013, 12:05 AM   #6
Jason@SportsCar
Is that 110 leaded? If it is you will be shortening the life of your catalytic convert and risk fouling your plugs. There is no reason to run that on an n/a motor with stock compression. The car was built for 87, 91 is more than enough even for track conditions.
Old 12-01-2013, 12:55 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
^ +1
I had considered running C16 in my car this past Labor Day Weekend for the speed trials, but after careful research it was proven that even with a high flow cat setup like mine I could easily plug it up within a couple runs which in the long term would not have been worth it. THERE IS NO REASON IN A STOCK 1NZ OR OTHER TOYOTA MOTOR IN TODAY'S VEHICLES TO RUN OVER 87 WITHOUT FORCED INDUCTION.
Old 12-01-2013, 11:37 PM   #8
ivanstepul
where did u turbo your cars? how much does it cost?
Old 12-02-2013, 03:31 AM   #9
willygoodness
Drives: 09 yaris hb
in Aus. the lowest octane we can buy is 91. using 98 i get around 90-110km more to a tank
willygoodness is offline   Reply With Quote
Old 12-02-2013, 01:02 PM   #10
UberSilver
UberSilver's Avatar
Leaded race fuel will gum up your engine. My stock engine likes 91. If I use 87, it pings like crazy. With 91 it's smooth as silk with little to no pinging.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
Old 12-02-2013, 02:05 PM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Stock engine shouldn't be pinging with 87, also the motor has a knock sensor.
On my car with a piggyback and a custom header and exhaust I don't have any knock or detonation issues even after an hour on track. Anything over 91 is definitely a waste on a stock NA setup.
Old 12-02-2013, 03:30 PM   #12
Jason@SportsCar
The ratings are done differently around the world. Your 91 is going to be similar to our 87. In the US we typically see the (R+M)/2 spec listed, your number is based only the RON, which gives you a number 4-5 points higher for the same grade of fuel.
Old 12-11-2013, 06:01 AM   #13
willygoodness
Drives: 09 yaris hb
^^ ahh cool, good to know
Stay tuned Jason@SportsCar Tracking, Racing, Auto-X Forum 1320 11-21-2021 10:03 PM
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 01:12 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
