Old 12-10-2013, 10:43 PM   #1
09sedan
Drives: 2009 yaris sedan
Fuel Door Release cable broken
i think i broke my fuel door release cable, its a 2009 toyota yaris sedan, how do i open the fuel door without using the release pull beside the drivers seat, i tried to pull it ( it was cold outside today) and it wasnt moving anywhere, i tried hitting the fuel door to try and loosen it up and it did nothing , i then rage pulled the lever and felt it break something ( car is at mechanics now )
any way of fixing this myself?
09sedan is offline   Reply With Quote
Old 12-11-2013, 05:58 AM   #2
bronsin
bronsin's Avatar
Maybe something is frozen by water and cold weather?
Old 12-11-2013, 05:59 AM   #3
bronsin
bronsin's Avatar
Originally Posted by 09sedan View Post
, i in a then rage pulled the lever and felt it break something.
Old 12-11-2013, 10:44 AM   #4
The fuel door release cable runs from the lever through the inside of the car (under the door sill plates and then along the side of the hatch or trunk. It ends with a plastic finger that pulls in when you pull the lever. My bet is that the cable pulled out of the tail of the plastic finger when you forced it with the door stuck.
You should be able to access the latching mechanism from inside of the trunk. On a hatchback it is right behind the rear tail light, but on the sedan it will be a little forward of the tails.
If the cable or finger are broken, I have one on hand if you need it.
Old 12-12-2013, 06:09 PM   #5
09sedan
i snapped the cable (literally) , it was all rusted inside and seized up, bought a new one from a dealer for 60$ and mechanic charged me 60$ to replace it since i didnt have time to replace it myself due to work :(, i added some grease on the cable to prevent it from happening again.
Old 12-13-2013, 05:54 AM   #6
bronsin
bronsin's Avatar
Great!
$120 to fix a broken cable?
YIKES!
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 325 05-12-2024 01:43 AM
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
