Old 03-31-2014, 09:11 AM   #145
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The 4e-fte was direct from Toyota with forged internals. Very easy to make a lot more out of it and less of the electronic control and bullshit of today's engines. Yeah, you would need a little bit of fab work, but would be interesting I think.
From my m-o-b-i-l-e
Old 03-31-2014, 09:33 AM   #146
fnkngrv
fnkngrv's Avatar
Originally Posted by Bluevitz-rs View Post
For the same power and way better fuel economy, the 2ZR is the far better option.
Personally I can't really understand why someone would even consider FE if they are going to go through the process of a full swap. THE 4E-FTE is lighter than the 2zr, has stronger rods, and a very nice compression ratio of 8.5:1. Also it has a lightened crank from the factory. This motor has the ability to easily get 38-44mpg on the highway in the Yaris paltform even om the higher boost setting for the internal wastegate. Around 32-35 in the city I bet too. Since it doesn't have all the other electronic BS required as the newer engines I have known guys that have bumped it to 1 bar of boost, kept their FE, and been around 165-175hp handily. Then if you wanted to get really into it you can get 260-300hp out od it without even changing the internals. You won't do that I don't believe with the 2zr.
From my m-o-b-i-l-e
Old 03-31-2014, 09:36 AM   #147
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Stock motor vs stock motor.
Sent from my iPod Touch
Old 03-31-2014, 11:38 AM   #148
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
If I am going thru all the trouble of doing a swap like that (fab mounts, fab wiring for ecu, fab axles/hubs, shift linkages, pedals for throttle cable), I would go with a 2zz motor. Stock vs stock. and even then the supercharger for the 2zz has alot of aftermarket parts for it, from the lotus, that are reliable upgrades.
I would like to do a 2zz swap, but I think the 2zr is going to be the best I can do since its been done and a fairly good write up on it on MicroImage website. That is if I do end up doing a swap. But the 1nz is a good platform as well to do a turbo as Garms old Yaris has shown us. As well as Blown xA and a couple other here who boost the crap out of thier 1nz. I think the only real issue with the yaris is the ecu. Damn thing is like a steel trap and is smart as f*ck
-Derrick-
Old 03-31-2014, 12:54 PM   #149
fnkngrv
fnkngrv's Avatar
I hear ya rice. I just think that it would be cool if someone did the 4e-fte swap showing another real option. I had considered the 2zz a long time ago then dismissed it because of the extra couple hundred pounds it it could end up being on thw front suspension. If you do the 2zr just make sure it is from the xD and not the previous years sin e there is the documented oil consumption issues. Yes the 1nz is a very capable engine, but as many have noted a pretty expensive one. Just a harness, switch to MAP, and full standalone is over 2k and I speak from experience.
From my m-o-b-i-l-e
Old 03-31-2014, 01:57 PM   #150
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
From my m-o-b-i-l-e
Aren't you going to run into that issue with any Toyota engine? I don't think any Toyota OBD2 engine has great tuning support outside of the trucks.
I'm stuck dealing with OBD1 tuning issues on a Miata, and I just can't see why you would want that. OBD2/CAN is great from a tuning, and diagnostic standpoint.
Old 03-31-2014, 02:19 PM   #151
ilikerice
ilikerice's Avatar
Agreed, definitely a viable option compared to some. thanks for the tip on the xD. Agreed on the weight of the 2zz, but that stock rev limiter... I wants!
In a year or 2, never knwo what may drop in my lap. May come across a wrecked xD or Celica gts... I am rebuilding a 4age motor, but I don't think I wanna go that old school in a yaris.
-Derrick-
Old 03-31-2014, 06:48 PM   #152
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The 2ZR is being developed for the Lotus Elise, supercharger and all. I'm also entertaining pipe dreams of a 2ZR swap followed by a Blitz mod. Lots involved in that one.
That said, a 2ZR spec sheet I found lists a 0-60 mph time comparable to my 1NZ + Blitz, so it's more or less the same benefit.
Old 03-31-2014, 09:13 PM   #153
ilikerice
ilikerice's Avatar
-Derrick-
Old 03-31-2014, 10:02 PM   #154
CrankyOldMan
Disregard, the 2ZR-GE supercharger is only available directly from Lotus in the UK. The only way to get one would be to buy it from them (assuming they would even do that) and then get standalone management. I already own the Blitz, and am not afraid of making my own conversion parts to get it on a 2ZR.
Old 04-01-2014, 08:45 AM   #155
ilikerice
ilikerice's Avatar
Jezus cranky.. thanks for that dissapointing post... crushed dreams
-Derrick-
Old 04-01-2014, 08:49 PM   #156
CrankyOldMan
Bah, you don't really want to come play in SMF. The PAX modifier is murder on our little cars. =P
Old 04-01-2014, 09:08 PM   #157
fnkngrv
fnkngrv's Avatar
Thomas has an OBDI 4ag and doesn’t seem to be having any problems. The beauty with the 4e-fte is that it gives you options down the line since it has beffier rods stock and a great compression ratio stock as well.
From my m-o-b-i-l-e
Old 04-01-2014, 09:14 PM   #158
ilikerice
ilikerice's Avatar
Yea, I would like to play in SMF one day.. I think I can do some damage with 100 more hp and 275 A6's or at least some ventus z214 to save some money.
-Derrick-
Old 04-01-2014, 09:37 PM   #159
yariseggvvti
Drives: Yaris Hatchieback
K20A 225hp engine with independent rear suspension that will be a perfect set up for Yaris.
yariseggvvti is offline   Reply With Quote
Old 04-02-2014, 08:35 AM   #160
ilikerice
ilikerice's Avatar
Agreed, GOD the rear suspension is the one thing I can't stand about the yaris. It's the one reason I want to return to stock and get something else.
-Derrick-
Old 04-22-2014, 11:22 PM   #161
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
PICS:
2zz
monchito18 is offline   Reply With Quote
Old 04-23-2014, 04:40 AM   #162
ilikerice
ilikerice's Avatar
Damn, I bet that 2zz is a monster.
-Derrick-
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
