07-08-2011, 09:59 PM | #37 |
Drives: 08 liftback 5 speed Join Date: Jun 2011
i took the front bumper off and the headlight cluster out. too much work for a light bulb. does anyone know what that peanut bulb under the main headlight bulb is for?
09-21-2012, 08:17 PM | #38 |
Success
Thank you everyone. I just replaced my bulb! The only reason I could do it was because I have child sized hands!
09-21-2012, 09:18 PM | #39 |
やりすぎだ~
Like the one in your profile pic?
10-25-2012, 10:01 PM | #40 |
Drives: Yaris Sedan Join Date: Oct 2012
Easy as butter
I was able to change the driver side bulb on an 07 Sedan with a needle-nose plyers. Rubber boot came right off by pulling on the rubber tabs that protrude out. From there I just unclipped the metal arm that holds the bulb and it came right out. Took about five minutes.
10-25-2012, 10:15 PM | #41 |
#yyc
Drives: BSP '07 RS 5dr LB Join Date: Aug 2011
If you go the bumper removal route, then it's a perfect time to throw on a DIY lip.
10-26-2012, 05:17 PM | #42 |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
Peanut bulb
11-13-2012, 02:36 PM | #43 |
Drives: 2001 Yaris 1.0 Join Date: May 2010
My wife's 2001 Yaris had an odd problem; offside sidelight and nearside dips were dead, but the beams were both fine.
On my Puma the enclosures are very similar, 3 screws, a good tug and they're off (no need to remove the bumper mind). I was surprised to find only one large bulb in the headlights. I replaced both sidelights, and the two main bulbs (h4) with some extra-bright, while still road-legal ones. Now are 3 positions (side, dips, beams) work fine. If the bulb was faulty, surely the beams shouldn't have worked? |
01-14-2013, 05:46 PM | #44 |
Drives: Yaris 2007 3 doors Join Date: Jul 2009
Tricks , shortcut .
I just did this bulb change , first I'd like to say thanks
to the ones who suggested to move the bumper cover , I did not remove it completely ,as some members suggested, just remove the 5 push pins on top ,and one on each side in the wheel well , pull the cover , a tug for the side to unclip the 3 clippings on each side between fender and bumper cover. once it is moved forward you can see the 3 10mm bolts that hold the cluster ,one at top , one at the front ,it is revealed when pulling the bumper cover , the 3rd on the side where fender meets the bumper cover , all 3 of those have a nipple in the middle and you have to lift the cluster a little before pulling , some for install clip cluster around the nipples , it will click , then screw . . Once you have the cluster pulled and turned upside down , it is very easy to undo the bulb , for the rubber boot over the bulb , just pull hard , and to put back , twist it on the new bulb , use a small screwdriver to push the pins back down around the new bulb if you have big hands . . If you go to canadian Tire , disregard the book that hangs in the isle , because it says to use the #9005 bulb .. it is the wrong bulb , you need the # 9003 , the terminal plugs in straight in back of bulb , the 9005 is a 90 degree angle terminal , (( it is wrong for my 2007 anyways )) . since I had the front hanging , I changed both sides $8.73 each for the bulbs , I don't want to redo this in 3 weeks on other side . 2 new lights and the one that was still working is now a spare in the toolbox. |
09-27-2013, 04:22 PM | #45 |
Drives: 2007 Toyota Yaris Join Date: Sep 2013
Not sure how the rest of you do it; changing the headlights is impossible without removing the bumper. I only took it partway off so that It would give me enough space to pop the headlights out. I took one of the old lights out before I removed the bumper...at least I took the base out. The glass shards remained inside the light (broke when I tried to get it out), I had to dump the glass out later (not ever doing this again without removing bumper). Anyway, found a vid on youtube about removing the bumper, did that, and then it finally got easy.
With the rubber boots, rather than cutting a larger opening like some suggested, I just put a flathead screwdriver inside between the light and rubber and pried it up all the way around. That worked well. Hats off to anyone who can do this without taking the bumper off...no idea how you do that. |
04-23-2014, 12:30 PM | #46 |
Drives: 2008 Yaris HB Auto Join Date: Apr 2009
Just to bring the old thread back from the dead........ I found this You Tube Video that is pretty clear as to how to remove/loosen the bumper cover.
https://www.youtube.com/watch?v=PlN6wC8hon4 |
04-24-2014, 12:08 AM | #47 |
4 years of P90X!
um.... I've replaced mine on the side of the road... in under a minute. I dunno what the problem is!
04-25-2014, 08:33 PM | #48 |
Drives: '10 Yaris LB Polar White Join Date: Oct 2010
I can get the bulb with some torn skin, nothing serious yet I see it as my blood and my car have become blood brothers.
10-30-2014, 03:27 AM | #49 |
Drives: 3-door hatch Join Date: Oct 2010
Arrrrgghhhh!! My driver's side bulb just burned out...
I was wondering: instead of loosening the bumper and light housing, can you just loosen the fuse box? TIA Also, that little parking light bulb burned out as well... |
10-30-2014, 12:40 PM | #50 | |
11-23-2014, 09:24 PM | #51 |
Drives: Yaris 09 Join Date: Oct 2014
Thanks to this thread, I was also able to replace my dimming headlights. It was fairly easy. I don't think I would have been able to do it, without loosening up the bumper.
I didn't have to completely remove it though. I just undid all the clips, and pulled the bumper out enough to have enough room to get the socket wrench in. I watched the video posted on the thread to give me an idea how to get the clips out and the bumper unfastened. With the headlight assembly out it's easy to see how everything works. The lightbulbs can only sit one way. So, doing it without seeing how it goes in, might have been the the culprit of mine pointing to the side when a reputable Toyota dealership in Canada gave me my Yaris. So anybody with a burned headlight, give it a go and save yourself a few bucks, keep the DIY spirit alive. |
11-23-2014, 09:56 PM | #52 |
11-23-2014, 11:33 PM | #53 |
Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
Changing the bulb without touching the bumper is all about hand size. The bulb has been replaced twice on each side on my 2007. Re the first replacement, I tore some skin trying to change the first one, until I realized my hand was too big. I took it to a local Toyota dealer, and I believe they charged me $16.00 to put the bulb in. I've also taken the car there for the last three bulb changes (all four times, I bought the bulb elsewhere) and they either didn't charge me for any of those three...or may have charged me $16.00 for one of the the three. Someone has always been available who has a small enough hand.
01-23-2015, 10:30 AM | #54 |
Drives: 07 Yaris Liftback Join Date: Nov 2010
Just got done changing my 07 Liftback's lights and I must say, it was taking forever as I initially gave up after the first 5 minutes. After a bit of research, I'm surprised no one posted any service manual pics on here of how the retaining clips worked. There was no need to pull the bumper cover and remove the headlights. My hands are relatively large and I too initially had an issue pulling the retaining clips together to release the headlight.
The bigger issue that wasn't mentioned here was the fact that the boot seal was seized onto the headlight bulb with the devil's grip. People on other forums said to use a screw driver to pry it off but I couldn't even get the screw driver angled correctly to pry the boot off. What I did was I reached behind the boot cover and pulled one side of the retaining clip to release that side but had trouble releasing the opposite side. So I grabbed my house key and jammed it between the headlight housing and the other side of the retaining clip to release it. Now all I had to do was pull the boot cover out with the attached headlight bulb. This all took maybe 5 minutes total regardless of how lengthy the process may have sounded. I'll attach the pictures from the service manual on this post to show you guys how the retaining clips work as well as how to remove the bumper cover for those who choose to go that route. Last edited by 07liftback; 01-23-2015 at 10:45 AM. |
Similar Threads | ||||
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
Changing Headlight Bulb Tutorial | RSboyz | DIY / Maintenance / Service | 29 | 03-15-2007 01:35 PM |
Yellow, Purple, Green Headlight BULBS? | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 12 | 02-04-2007 08:30 AM |
Side Turn Signal Lights | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 15 | 08-24-2006 06:06 PM |
