Old 05-10-2014, 06:58 PM   #55
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
This isn't her beam. But basically carefully cut the hub mount bracket off and move it in and reweld it should pull the wheel in more?
sasquatch is offline   Reply With Quote
Old 05-10-2014, 09:42 PM   #56
That's not a 2nd gen Yaris one, but the pic below is. The one tricky thing is that you want to cut out a section to move it in, but at the same time you need to maintain the distance from the pivot point or the wheel will no longer be centered forward to back.
Old 05-10-2014, 10:02 PM   #57
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
Attachment 53490
ahhhhhh i see, i blame google for the wrong image haha. we will have to get under the car and take a look at what kind of room i'm looking at and what area would be best to remove material from. Then speak with a friend who does fabrication work and see about what could be done. not going to give up yet!
DINOeggxo is offline   Reply With Quote
Old 05-10-2014, 10:37 PM   #58
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
now that i have read this think im gone save my hub spacers for the next Yaris ...any idea if this problem is on 2012 up ?
Old 05-10-2014, 10:38 PM   #59
It is definitely a cool idea. I had a spare beam that would have been perfect for you to experiment with, but unfortunately someone else grabbed it to replace a bent one.
Yaris Sport 2009 wheels question andr3w Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2013 07:28 PM
hid hi/low. question on using high beam for DRL! marcus Cosmetic Modifications (Exterior/Interior) 22 06-17-2010 03:12 PM
