Old 11-04-2014, 10:00 PM   #289
Originally Posted by 62Fender View Post
Hope you don't mind a question from a non-Yaris owner?
Great thread! I imagined a ~$10 mod would look like it but it's every bit as aesthetic as functional. I installed an oem kit stalk and it's almost in the way compared to dash buttons.
The basic Scion TC "CRUISE" light does not have a "SET" indicator. Is it possible to add a single LED as a "SET" indicator without having to tap the CAN circuit?
No. For set you would need the CAN message from the ECM.
Old 11-05-2014, 12:57 AM   #290
62Fender
Drives: Scion TC
Cool. My ECU diagram lists CAN L and CAN H. Would a voltage test during cruise "set" indicate which CAN could be tapped for the hot side of the LED? Opposite side of LED to ground?
62Fender is offline   Reply With Quote
Old 11-05-2014, 06:45 AM   #291
The CAN bus is a high speed computer network. You would need an intelligent device to decode the messages and light the LED when the appropriate message comes across.
What year is your TC?
Old 11-05-2014, 10:37 AM   #292
62Fender
Drives: Scion TC
Are we talking wave form instead of voltage? I probably better stick with the basic cruise light.
The TC is a 2008 'spec'. Thanks for the info.
Old 11-05-2014, 11:35 AM   #293
Even more than wave form - We are talking about an encoded message within a stream of pulses. I actually have an enhanced version of my cruise control indicator module that I developed, which can drive separate LEDs for ON and SET. I haven't offered it for sale as of yet, as it is a $50 device, as opposed to the $25 one that just handles reading "ON" via the feed between the switch and the ECM. Set is more complex, as you really need the message feedback from the ECM to know that all conditions were met to allow the ECM to set it.
Old 11-06-2014, 03:02 PM   #294
62Fender
Drives: Scion TC
Thanks for the info. Any plans to make the 'set' indicator available separately?
Old 11-06-2014, 03:37 PM   #295
I can easily do that. It is just a matter of not having the second LED for "ON".
Old 12-18-2014, 09:03 PM   #296
62Fender
Drives: Scion TC
Dear CTScott,
Was wondering if this idea could be applied to remote audio controls, (ie seek/volume) without having to fork for the steering wheel upgrade? My head unit has the wires that typically go to the clockspring. The volume dial has to be turned too many times to be useful. I'd like to have an up/down rocker-type control if possible.
I thought about using two rockers for volume and seek plus a momentary switch for the "mode" selector.
Is this possible without adding resistors to the switches or does the head unit require variable voltages to know which switch is being pushed?
Old 12-18-2014, 09:39 PM   #297
Dear CTScott,
The headunit would require resistors for each function. If you have an aftermarket one, some of those use more complex methods than resistance.
Old 01-15-2015, 07:43 PM   #298
andreas14
Drives: Toyota yaris
CROUSE
can this work with vitz 2005 2SZ-FE SMARTKEY(KEYLESS ENTRY START BUTTOM) NO KEY AND IGNITION SWITCH HOLE
andreas14 is offline   Reply With Quote
Old 01-15-2015, 08:06 PM   #299
No. There is no easy cruise solution for the Vitz.
Old 04-03-2017, 08:34 AM   #300
Dohsh77
Drives: Yaris
After all this years did any one find how to install cruis control for yaris if the measure between pin 40 and ground is 0 volt
Dohsh77 is offline   Reply With Quote
Old 04-03-2017, 08:36 AM   #301
Dohsh77
Drives: Yaris
My car is toyota yaris sedan 2010 with ecu 89661-52c00
Old 04-03-2017, 07:34 PM   #302
If pin 40 is zero volts, then your only option is an aftermarket solution, such as the original Rostra kits (the kits with the non-OEM looking stalk).
Old 04-03-2018, 01:52 PM   #303
David C
Drives: White '07 3dr LB
Thanks again for the write up, today I just did my brother's car cruise control, after doing mine a while ago shortly after buying the car.
I've been wondering though why did toyota chose to have a non persistent CC function rather than always on like I've seen on other manufacturers. What's the idea behind the on/off design rather than just a standby ?
Old 08-30-2018, 03:21 PM   #304
Yarauto
Drives: 09 Yaris Base model
Recently ran across info from CTScott from 2009 on how to install a “two button” control on an 09 base model Yaris (The only luxury on this car is A/C).
Upon inspection of the D3 connector I found that there is only one black wire coming from that connector (no blue or brown wires).
Does that change the usability factor on this car for the “build my own” 2 button control system?
Thanks for any info you can provide.
Yarauto
Yarauto is offline   Reply With Quote
Old 09-24-2019, 01:06 PM   #305
giorgos01
Drives: toyota yaris 06 1.3
Originally Posted by PatrickJohnson View Post
it doesn't, the 07 and 08 don't have it, only the 09
without lamp and work right?
giorgos01 is offline   Reply With Quote
Old 12-27-2020, 10:28 PM   #306
Kasbien
Kasbien's Avatar
Drives: 07 Sedan (AT)
So I read through the entire thread but didn't find a solution my issue (some similar cases but no resolution).
I have an 07 sedan, auto transmission, Canadian car. I went to perform this mod today, only to find that I have a factory wire (pin 40) at the ECM connection but no wire at the D3 connection under the steering wheel. No CC lights in the cluster either. Car has been dealer serviced since day 1.
Anyone else figured this one out?
EDIT:
Found the solution in another thread. The pin 40 wire seizes to exist after the firewall connection (AD4) on the drive side of the vehicle. Weird! See attached photo. Hope this helps someone out because it sure as hell gave me headache.
File Type: jpg DIY Cruise Control Wiring Issue Fix.jpg (132.7 KB, 41 views)
Kasbien is offline   Reply With Quote
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
