10-13-2015, 12:26 PM | #1 |
Drives: Toyota Yaris/Vitz 2005 Join Date: Oct 2015
Need speedo with tach and with 220 km/hr range
Hi i have yaris 2005 with 1krfe motor. I currently have ugly looking speedometer and it dosnt have any tach either. I need a speedometer with tach and with 220 km/hr range and with temperature display. Mine is an auto transmission. Where to find and is it compatible would it be a bolt on thing? I dont have ECO thing. I need someones help here doing this
Waiting for your comments. Thanks Last edited by Sal_JapMechanic; 10-14-2015 at 09:15 AM. |
10-14-2015, 07:54 AM | #2 |
Drives: Sedan 07 Join Date: Oct 2012
Your best bet would be your local junkyard from a higher trim level.
10-14-2015, 09:19 AM | #3 |
thanks
10-14-2015, 09:46 AM | #4 |
You will not find a cluster that meets your listed requirements on North American shores.
10-14-2015, 11:31 AM | #5 |
Thanks for your comment. Then what do you suggest? and how one should check compatibility? tach and 200 km/hr range is what i need. Mine is an auto to P,N,D,S,B indication on the speedo as well with temperature reading.
10-16-2015, 08:56 AM | #6 |
Bump!!!
10-16-2015, 07:15 PM | #7 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Is your car right hand drive? Also, is it a first or second generation Yaris/Vitz?
If it is a second generation, I am only aware of the temperature display being on the digital instrument cluster, and that actually has a tachometer.
10-18-2015, 02:53 PM | #8 |
Thanks bro
Yes its a second generation and yup its RHD. Can you show a pic of that cluster ur referring to? Thanks alot for your comment.
10-18-2015, 06:36 PM | #9 |
10-19-2015, 12:50 AM | #10 |
10-19-2015, 12:52 AM | #11 |
Also i have noticed my seat belt warning chime and its warning light on the speedometer are not working. Dunno whats wrong
10-30-2017, 02:06 PM | #12 |
ManualTransmissionLearner
Iam VERY SORRY to bump that thread but... HOW did you changed the color of it? it's a turquoise color normally..... how did you turned it to blue ??
10-31-2017, 05:10 AM | #13 |
Enthusiast
Drives: 07 Yaris HB 1.3 (EU) Join Date: Nov 2014
With a filter. They're just coloured films really, you can make it whatever colour you want, just try different combinations of films :)
Cheers, George. |
10-31-2017, 11:36 AM | #14 | |
also do you have more info on them ?? I installed a "sport seat" in my Yaris, and the cluster is a little bit too high.. is there something I can do to reposition the cluster's screen to align it with my vision ? |
10-31-2017, 12:21 PM | #15 |
Buddy. Turn down the brightness of the cluster lighting.
Sent from my SM-G930W8 using Tapatalk |
10-31-2017, 04:18 PM | #16 |
Enthusiast
Unfortunately it's fixed. Also, you don't have to disassemble it at all. You can even take out the clear plastic without even unplugging the speedo, just unscrew it, tilt it towards you, and there are some tabs holding it in place. Try putting some coloured films on the speedo to see the result, till you find the combination that you like best, and then you can stick it in place. It's one of the easiest mods you can do. If you want an analogue cluster that's a really hard thing to do if you wanna change the colour. The analogue clusters have smd leds on the circuit board. I have some pics if you're interested
Cheers, George. |
11-01-2017, 10:51 AM | #17 |
11-01-2017, 02:09 PM | #18 |
Enthusiast
They dim when you turn your lights on. But what he thought is that the brightness of the cluster was bugging you with your new sear, and not the actual height. I think I covered your questions well. Cheers
Cheers, George. |
