Old 01-19-2016, 05:37 PM   #37
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Good to know. Could play a part in how people look at the swap for auto x, etc especially if they boosted it.
Sent from m-o-b-i-l-e
Old 01-19-2016, 10:19 PM   #38
3cyltrbo
Originally Posted by ArmstrongRacing View Post
And about emissions, everyone should check their own states laws before starting any swap. I already have permission from California to do this swap, I called in advance.
+1
Up here in Canadia (aka Canada), it varies from Province to Province and even different municipalities.
Where I live, I've never heard or seen of someone ever getting a ticket related to emissions / engine swaps etc....
And our emissions testing has moved away from sniffer tests (at least in my area) and now focuses solely on Check Engine Lights.
Personally If I go through with this swap, of a Toyota engine into a Toyota and one that will look like it belongs there, emissions and "Fix it Tickets" will be the farthest thing from my mind.
3cyltrbo is offline   Reply With Quote
Old 01-20-2016, 10:21 AM   #39
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I agree the bigger differential and axles would add a bit of assurance, but the gearsets are still the same parts from the yaris C50. I personally know 6 guys racing with the Yaris trans and no issues. The Yaris is a stout little car, power is its only downside.
ArmstrongRacing is offline   Reply With Quote
Old 01-20-2016, 10:35 AM   #40
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
As long as you're in the 150 hp range, you should be OK with the Yaris diff and drive shafts. If you plan on going into the 150-250 bhp range, I would recommend (without empirical evidence) going with the xD setup, if only because it is standard on vehicles with 150-200 stock bhp. Anything over 250 bhp will probably need custom shafts for longevity.
From a price standpoint, xD aftermarket diffs are normally cheaper than the Yaris, since it has more demand. For example, the Quaife QDF15E (Yaris) costs around $1100, whereas the QDF21E (xD/Celica/etc.) is normally under $1000. Keep in mind that the ring gear on the differential is NOT compatible between these two models, but the xD differential will potentially open up more options for final drive ratios--and potentially at a lower cost than the Yaris.
But enough talk about drive shafts. Let's get to that wiring! =)
Old 01-20-2016, 11:25 AM   #41
tmontague
tmontague's Avatar
Originally Posted by 3cyltrbo View Post
+1
The only thing you'd have to check with in Ontario is that I'm pretty sure they check to see if the ECU is giving off the correct vin that is on the body of the car. If not that may mean an instant failure of the e test. I'm sure you could easily get a waiver but I'd check into it before you do your swap. Let me know what the result is
Old 01-20-2016, 11:29 AM   #42
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Wiring.. everyone's favorite part... RIGHT!
Looking good Armstrong!
-Derrick-
Old 01-20-2016, 02:26 PM   #43
CrankyOldMan
Just a friendly reminder, if you have to replace the exhaust anyway, you should consider the xD long tube header from Fast Scions. I've got a mandrel bent 2.5" res-back kit that would be a great start on a mid-pipe for this. =)
Old 01-20-2016, 03:03 PM   #44
Rigaud
Drives: 2009 Yaris
+1
No municipality has a say in emissions in Canada. Regulated by Federal then Provincial.
Old 01-20-2016, 03:07 PM   #45
Rigaud
Drives: 2009 Yaris
No, you can replace the ECU...hence replacing it when it fails!!! Sniff test that's it via OBD. They check if theirs been any cel that popped up recently. Straight forward. My friend nearby in Kawkesbury just went through it with his Audi URS4.
Old 01-20-2016, 03:45 PM   #46
tmontague
tmontague's Avatar
so they don't check if the OBD is giving off the matching VIN to the body of the car? I thought if you end up installing a new ECU because the stock one was dmaaged then the dealership reprograms it to match the VIN of your car?
If that is the case then ya it'd be no issue.
Old 01-20-2016, 10:35 PM   #47
ArmstrongRacing
Data doesn't lie
If you were lucky enough to source a Xd engine harness, the plugs on the fusebox end are a direct match and the only wiring changes needed invole the speed sensor and MAF sensor.
CA2- top left
CA1- top right
Old 01-20-2016, 11:10 PM   #48
ArmstrongRacing
Data doesn't lie
Here are the highlighted pins that need swapping.
1) If you keep the Yaris transmission: Move the speed sensor wires over to the same spots in the Xd plug CA2.
1a) If you use the Xd transmission, your car better have ABS to steal the speed signal from....those are the only options I know of at this time regarding speed signals.
2) The MAF sensor power wire at CA2#9 has no supporting pin in the Yaris fusebox. I tried removing this wire from the plug and soldering it to another +12v wire in the fuse box...but the MAF voltage would fluctuate. My final fix was to cut the power wire 8" from the MAF plug and run a dedicated power wire via a mini-add-a-circuit in a IG switched fuse location.
Old 01-20-2016, 11:43 PM   #49
ArmstrongRacing
Data doesn't lie
If you couldn't locate a Xd harness than your swap(like mine) is going to be much more involved wiring wise...
The Corolla harness has 3 plugs on the fusebox end and none of them match the yaris. You must move every single wire to its corresponding location in the yaris' CA1 and CA2 plugs.(I'm almost done). In addition to re-pinning, you will also have to cut the 2zr harness battery cables going to the starter/alternator and connect them to your 1nz harness cables for the extra length and the proper ends....lots of work.
NOTE: You can see my mini add-a-circuit for the MAF here
Old 01-21-2016, 04:24 AM   #50
beaker
Drives: 07 Yaris 3 door
So the MAF (CA2#9) needs to see +12volts with ignition on? It's not a signal coming out of the MAF with variable voltage output going back into the ECM?
beaker is offline   Reply With Quote
Old 01-21-2016, 04:37 AM   #51
ilikerice
ilikerice's Avatar
I understand what your saying but can I suggest a bit of rewording... Try to do a step by step process in 1 post for the wiring with what you have acquired (yaris harness and yaris Trans).
-Then have a separate post if you use the yaris harness with xD trans,
-another post for yaris trans with the xD harness,
-and another post for the xD harness and xD trans.
After that is done, if you could go ahead and mention corolla parts.
You are mixing scenario's up in 2 different posts and I can see how this can get confusing and intimidating for someone who is a newbie with wiring. I used to work for Toyota and Lexus for 6 years, so its a bit easier for me to understand.
Great job though. looks fun, I can't wait to do this to mine! I have been talking about doing this for a LOOONG time when I found out that the 2zr was the Yaris TS version.
-Derrick-
Old 01-21-2016, 07:07 AM   #52
fredovvti
Drives: Yaris 07 HB
If I get a complete xD harness and use the Yaris trans, I only have to move the pins that you mention in post #48 to the correct location of the plugs ends and that its?
fredovvti is offline   Reply With Quote
Old 01-21-2016, 10:07 AM   #53
ArmstrongRacing
Data doesn't lie
Correct. The MAF black wire is the power supply to the sensor....the other 4 wires go directly to the ECM.
Correct, for now. There is more wiring later but this is all regarding the engine.
Old 01-21-2016, 10:32 AM   #54
ArmstrongRacing
Data doesn't lie
Im sorry for the confusion, but I mention the Corolla harness because thats what I'm using on my 2zr/yaris trans buid. I wanted to test ALL of the Corolla parts so no one else would have to. I want this to be easy for everyone, so again just to be clear........aside from the actual engine and accesories, USE EVERY PART FROM A SCION XD.
I know you guys would prefer this diy be formatted a certain way, but I am sharing this info with you guys as I go.
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
