Old 07-16-2016, 02:22 PM   #1
Yaris_Mac
Drives: Gas saver
'08 Yaris hatch Flywheel/Clutch recommendation
Hi,
So my throw-out bearing is making noises again. First was under warranty at 25k miles and then now at 60k. I also don't really like the clutch on this car. It's like an ON/OFF switch. It's not smooth at all and I've only had manual cars since 1992 and this is the only car that does that. Now that I'm going to replace the throw-out bearing, I might as well change the clutch kit but since I'm already down there, might as well replace the flywheel. You know how it goes...
So, I'm looking for:
Lightweight flywheel in steel or aluminum, 8-9 lbs.
Performance clutch kit that is good for daily driving in the city.
Which flywheel and clutch kit you guys would recommend?
Currently the car is stock 1NZ-FE but I do plan on adding 20whp by end of the year. I just don't know the route I'm going at this time (s/c or n/a).
Thank you!
Yaris_Mac is offline   Reply With Quote
Old 07-16-2016, 03:29 PM   #2
Here's one of the existing conversations in case you haven't searched out prior topics.
http://www.yarisworld.com/forums/showthread.php?t=55512
There is probably more insight from some of the older threads than you will get now due to reduced forum traffic.
Old 07-16-2016, 05:27 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
DO NOT DO WHAT I DID!
Do not get a springless stage 4, 6 puck clutch. make sure your chose one with springs to dampen the shock and make it easier to drive in traffic. My choice was great if all i did was race my car, and being faster than an IS300 with intake and exhaust was fun, but the head ache of not being able to easily ease out on the clutch and cruse with out having to fight the car wanting to launch.
Basically i have a stage 3, sprung clutch on standby already to go in when i get a chance to change it out.
I also have 20k miles on the springless clutch, seems to be wearing fine, just not as DD friendly, and makes me want to drive it faster which makes the wife not as happy.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Getting ready to buy a 2007 Yaris hatch Type456 New YARIS Purchase Forum 26 02-16-2014 11:48 PM
Newbie here, just got a 2010 Yaris hatch! Deathegg New YARIS Purchase Forum 18 03-27-2011 11:48 AM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
